Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I recentally relaced an old thermo, w/ a new rth2310b honeywell thermo, for some reason , during the first cycle of useing the heat...The furnace will run properly and heat the house to the correct temp and shutdown. Then when it kicks back on to maintain the correct temp, the gas flames kick on and off 3 times and the fan keeps running without any heat producing, just blowing cold air, not maintaing the temp? The thermo shows the flame indicator being on, however there is no flame on at the furnace, just the fan running?
  • 2 more comments
  • spaceghost77 Jan 25, 2009
    never had a problem before, I did however clean off the ceramic igniter alittle to try and see if its the igniter not the thermo? still waiting to see what happens. Aby suggestions, is this thermo compatible with a Trane Xe 78 ?
  • Pyldrvr May 11, 2010
    If the thermostat is digital make sure that if there are any switches that they are switched to the proper settings..such as gas or electric hp or non. Yours should be set to gas and non since you have a gas furnace. If you have all this set corectly you may just have a problem with the furnace itself. How old is the furnace and what brand.
  • Dale Koehn
    Dale Koehn May 11, 2010
    I hate to say this but you should never clean the Hot Surface Igniter, if it gets any kind of oil, cleaner or anything on it, you will have to replace it very soon as it will burn out, now are we talking about a thermocouple, or flame sensor ? now as far as your flame sensor, it might show that it is a green or yellow light on the board, but it still may not be letting the proper amount of voltage through to keep the burners lit, I would recommend that you remove the flame sensor and use a piece of emery cloth to clean it then reinstall, if it is a thermocouple, which I dont think it is you would need to replace it, now one other device in your furnace is called a pressure switch, it is a round sort of flat piece that has a small rubber tube running from it, and two wires, the pressure switch is normally located in the front of the service area of the furnace, remove the tube from the burner box or what ever it is attached too, you will have to probably do this a few time to get the timing down, **** on the tube, as you fire off the unit, you will hear a click when you apply suction to it, you will have to maintain suction through the sequence of operations, once the ignitor glows and the gas valve opens, you should see if the flames will continue to operate at that point, when you let off the pressure switch, the flames should go out, as the pressure switch is powering the gas valve, I would try this after trying the flame sensor trick, if you do have to go that far with the pressure switch, and after you have tryed that, and hooked it all back up, if it fails again, replace the pressure switch, I hope this clears up a little more about what to do and what to look at, let me know if you need anymore assistance, thanks,
    mr.grzz
  • Dale Koehn
    Were you having this same problem before you changed your stat ? or is this a whole new problem ?
  • Honeywell Master
  • 3,238 Answers
Hi sounds like the pressure switch is faluty try jumping out to see if it starts
Posted on Jan 28, 2010
  • 24 Answers
Dirty flame sensor
Posted on Aug 10, 2009
    Problem Solver:
  • 8 Answers
Check your air switch mak sure its closed also check the high limit
Posted on Mar 13, 2009
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
I have a RTH2310 and it ran ok with A/C all summer but does not turn on the furnace now
The furnace may not be getting power. It could have been turned off when switched over from heating to cooling.
Oct 27, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
I purchased a rth2310b and connected the red wire to the RC and white to w the green to g. It still will not start furnace. This is a gas forced air.
I think there is connection labeled Rh. The reason for having Rc and Rh is that some units have a transformer for the heating unit and seperate on for the cooling unit. If you only have 1 transformer then they have a jumper between Rc & Rh. Rh being for heating and Rc for cooling. Hope this helps. Let me know what you find.
Aug 09, 2010 | Honeywell Programmable Thermostat Heater
I installed my RTH2310b honeywell, and called tech support because my old thermo had two connections, and none were labled. I have a gas furnace and hot water heat in a 1911 era home. Sop the guy I could...
Was there a jumper wire from the Rc connection to the Rh connection? And did you remove it? If you did you will need to re-install that jumper wire. You will need to use the jumper wire when you have a older furnace with just two wires. Verify that information with the instruction manual that came with the thermostat. And make sure that you always disconnect the power for the furnace before working on or changing the thermostat wires because it uses 24volts and you could shock yourself(24 volts stings a little) and or short out the voltage regulator for the furnace. Also some older furnaces require a thermostat with a "heat anticipator" setting and may cause a problem with the furnace if a compatible thermostat is not installed.
Nov 11, 2009 | Honeywell Electronic Programmable...
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were...
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Jan 01, 2009 | Honeywell Focus 6300B 5-2 Days...
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
637 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
