Question about Treadmill Doctor Exercise & Fitness
TO CHANGE ELEVATION OF LIFESTRIDER 3325 TREADMILL
HOW TO ADJUST THE HEIGHT ELEVATION OF THE LIFESTRIDER 3325 TREADMILL
3 Suggested Answers
dgforeman
  • 29 Answers
SOURCE: dp lifestrider 3325 treadmill
Dp went out of business many years ago. S & R Workout Warehouse bought all their parts. They are in Tyler Texas at 903 581 6568. I just talked to them yesterday. Central time 8-4:30
Posted on Jan 28, 2009
maxtreadmill
  • 832 Answers
SOURCE: Lifestrider 3325 will not turn on.
Keep unit unplug check your outlet if power is good then plug unit in make sure your safety is engaged if that does not work, open motor shroud and under that shroud their should be a paper with a wiring diagram and with a Ohm meter check where you have a open circuit.
Posted on May 06, 2010
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem.
Since you already installed your motor you can go straight into diagnostic mode.
To get into Diagnostic Mode on your L8
Make sure to turn off your treadmill.
-ET's - Press Menu and Start at the same time
-CT's - Press Manual (or Display^) and Start at the same time
-All other L SERIES mills - Press Display (or display and Start at the same time
SideNote-
-*CT's that were manufactured after 09/2003 - Press Display and start at the same time.
Few things you want to do, if you haven't already.
A. Align the motor with the clevis mount and install the motor mounting pin.
B. Insert hitch pin.
C. Reconnect the elevation harness to the lower board
D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click.
E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft.
F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws.
To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing.
G. Calibrate the elevation potentiometer and to do so you must;
1st: Visually confirm treadmill is leveled. (0% grade)
2nd: Adjust the settings as follows;
All L SERIES millls should read 0.0
3rd: If the setting is incorrect, follow these steps.
Step 1: Turn the post of the potentiometer all the way
CLOCKWISE.
Step 2: SLOWLY turn the potentiometer COUNTER
CLOCKWISE until the setting is correct.
H. Carefully install potentiometer into the motor housing
*NOTE: The setting may vary when inserting the potentiometer
into the motor. As long as the change is minimal, fine
adjustment can be achieved by rotating the meter
while inside the elevation motor.
I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor.
For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith.
http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
Apr 20, 2015 | Landice L8 LTD Cardio Trainer Treadmill
Tip
How to calibrate a Vision Fitness Treadmill - Residential Models
If you are not quite sure about the speed/elevation of your machine you can perform the following to test/correct your Vision Fitness treadmill.
1. Remove safety key and then replace
2. Hold the elevation up and speed down buttons until it beeps 3 times
3. If you see the model of your treadmill on this screen make sure you hold enter and then you will see "eng1"
4. Use the elevation buttons to scroll to "eng4" and hold enter to select
5. you should see the word "auto" on the screen at this point
6. Making sure you are not on the treadmill at all, press start.
The treadmill will go through a few tests to determine the maximum and minimum of both speed/elevation. You can see the results on the display as it is performing this test and if there are any discrepancies the machine will adjust the settings to make the appropriate speed/elevation calibration.
If the test passes it will display "end" and from here just remove and replace the safety key. You should notice a difference in the speed right away.
on Aug 05, 2010 | Exercise & Fitness
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear
2) adjust the small POTentiomenter for to liberate the elevation motor
3) clean the relais contacts, and tight every connector.
see the diagram and fix it.
Jan 18, 2013 | Proform 860 Competitor Treadmill
Error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
Jul 08, 2012 | Sole Fitness F63 Treadmill
Treadmill making knocking noise
1)Please LUBE the rollers bearing very well.
2) Lube the deck belt very well, see the video,
3) Adjust the tension see the diagram.
4) Lube the rack and gear from elevation motor see the diagram and adjust the potentiometer, test the bearing from the elevation motor.
5) Test the bearing from MAIN MOTOR, and repair .
God bless you
6_14_2012_7_24_52_pm.jpg6_14_2012_7_25_14_pm.gif6_14_2012_7_25_40_pm.gif6_14_2012_7_25_59_pm.gif
Jun 13, 2012 | Exercise & Fitness
Ironman 3900 treadmill will not work. code L 14
1) adjust the speed sensor, clean and tight the wires connector very well
2) lube the gear and shaft from elevation motor
3) adjust the potentiometer from elevation motor
4) measure the input voltage from elevation motor
5) Try to run the software calibration, for diagnose, troubleshooting
God bless you
Jun 11, 2012 | Exercise & Fitness
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
May 05, 2010 | Exercise & Fitness
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Dp lifestrider 3325 treadmill
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
