Question about Frigidaire Refrigerator Light Switch - 5303289051
Frigidaire refrigerato light switch PS899597 - Frigidaire Refrigerator Light Switch - 5303289051
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer ice cold but refrigeratoer side warm
Must adjust the food compartment settings to a higher level. If that does'nt do it in 24 hours .You have a faulty evaporator fan....The evap.fan distributes cold air from freezer to food compartment...Jack Arevian
Jan 24, 2010 | Frigidaire FRS26H5AS Side by Side...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
May 14, 2009 | Electrolux 30" Built-In Single Electric...
Replace light switch in frigidaire freezer
it is very simple, disconnect power supply of your freezer. take two flat screw drivers and pull the defective light switch, disconnect the wires and fix it to the new switch and press the switch back to is original possition
Feb 02, 2009 | Frigidaire Refrigerator Light Switch -...
No water to ice maker or drinking water
No ice or water? It's almost a sure bet the primary valve has failed. Volt ohm meter handy? Almost any reading on the meter at the terminals on the valve will mean the valve is probably good. No reading, replace primary valve. Also check the fill tube at the icemaker to see if it is frozen, if frozen valve will probably be at fault.
Jun 26, 2008 | Frigidaire FRS26H5AS Side by Side...
Not Cooling or freezing.
you need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Sep 25, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire Refrigerator Light Switch - 5303289051 Logo
24 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
