Question about Dishwashers
Whirlpool ADP 4300, drainage problems. 4 flashes indicating that water is not draining. I have made sure there is no blockage and cleaned all the filters, even reset the program. What should I do next
    Problem Solver:
  • 4 Answers
Hi some times you will find that there is dirt in the pump itself that pumps water out there should be a screw cap on the front of the pump ,open that and clean it out ,After this take the outlet pipe and
lower it into a bucket and try again . this is just to see if there is more dirt coming out ,if so clean it again .
Then while it is pumping out lift the pipe to the same hight as the dranage outlet to see if its still pumping at that hight .hope this helps
Posted on Jan 18, 2013
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Whirlpool 7540 start light flashs 4 times
The #4 error code on your dishwasher says it's a drainage error and that the computer didn't detect that all the water drained out of the machine. Sometimes that can be caused by a blocked filter on the pump, a blockage in the drain hose or a water level switch failure...also it can be just a electronic anomalie and the board can be reset then the dishwasher will work as normal. Or of course it could be because the filter is clogged and needs to be cleaned so water will flow through it and drain out.
I have written tips both covering how to clean the pump filter and resetting the control board,refer to them and see if they will resolve your dishwasher troubles.
TIP FOR CLEARING THE ERROR CODES FROM THE BOARD
http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
TIP TO CLEAN THE PUMP FILTER
http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 28, 2011 | Whirlpool Dishwashers
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
4 flashes and beeping
4 flashes indicates a drain failure. Could be obstruction in drain system-first check drainhose for kinks, check where drain hose attaches to wastepipe spigot for blockage. If OK blockage may be in pump- disconnect from power, remove bottom panels to access under machine. Drain pump located front left- remove plug from pump, then there is a plastic tag on top of pump you must push down, then drain pump will turn and come off (it comes off easily if tag pressed correctly, so don't force it!!)
If pump OK, fault will be with water indicator switch-sometimes get full of muck. Open dishwasher door, remove filters and clean out any water from base. Right in the bottom right hand side of sump you will see a round black grill- this is water level indicator switch. If it looks blocked up, advise replacing (you can try cleaning, but replacing is best). To replace, access from under machine-again, this switch turns and pulls out, but can be quite difficult due to it being located behind the heating tube.
So, check hoses and pump, then press and hold start button for 3 seconds- this clears fault and resets machine. Try another cycle-if OK, problem solved. Recommend expert assistence to replace water indicator switch.
Aug 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
We are getting an F02 code indicating a drainage problem. It is draining properly but it is like it thinks there is still water in the tub, it's dry.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 15, 2009 | Whirlpool GHW9250M Front Load Washer
ADP 7966
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
Remove the filter on the floor of the machine, including the metal grill.
Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it.
My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Oct 22, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwasher not draining
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
Mar 05, 2008 | Dishwashers
Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Jul 31, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
206 people viewed this question
Top Dishwashers Experts
