Question about Health & Beauty
How to remove battery from salter 9044 bathroom scale
I got the battery door off but can't budget the batteries to get them out so I can replace them. Is there a way to get the batteries out? Thanks
5 Suggested Answers
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
I have a Salter 9007 bathroom scale. It stopped working so I bought replacement lithium batteries and installed them
Do you still have the manual with the troubleshooting section in it? It looks like this is an overload condiiton or an indicator that something is not right. The manual can help you to sort this out.
Mar 01, 2017 | Salter Health & Beauty
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
How to open battery door for salter MODEL 926 bathroom scale
The assembly doesn't come out, there is a tang for each battery and with a small knife you can get the battery over the tang and then with tweezers (or slender fingers) pull the batteries out one at a time, at least that is what worked for me. I tried to pull out the tray with needle nose pliers and forget it...do each battery one at a time
Jun 21, 2012 | Health & Beauty
The display on my salter bathroom scales is flashing error, i have changed the batteries, this did not help
Oct 19, 2009 | Salter Health & Beauty
Aug 25, 2009 | Health & Beauty
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
94 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
