Question about Bosch SHX43R55UC Dishwashers : Built in Dishwasher
I just installed a Bosch shx43R55UC/64. Upon starting all lights are on and I cannot select a cycle. When I shut it the unit starts but will not fill with water. The float switch is working, No wat
When manually moving the red arm on the float I can get the drain pump to kick on if it is raised and shuts off when it is lowered. Putting my voltage meter on the float switch I get continuity to change from the top to middle when it is up and from the top to the bottom when switch is down
  • Nate Neufeld Jan 18, 2013
    I get 120 volts down to the water inlet valve but the valve is not opening. I replaced the valve with a new one but still does not open
    The float switch appears to be functioning in that I get 120 volts to the inlet valve when float is down and nothing when I manually raise the float.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
U need to clean out the water chamber on the left hand side and the diofram too
Posted on Jan 18, 2013
  • Nate Neufeld Jan 19, 2013
    The water chamber is empty. It does not appear to ever have had anytihning in it
    I have also disconnected the line leading to the water chamber and nothing is getting past the inlet valve. I have replaced the inlet valve with no difference
  • 1462 Answers
SOURCE: how to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Posted on Jun 25, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
  • 423 Answers
SOURCE: Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
Posted on May 09, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
BElectric
  • 1140 Answers
SOURCE: Hello, my Bosch Classixx dishwasher SGS43E42EU/21
Hello Dave,
Sounds like an overfill problem - the symptoms are consistent with a failed pressure switch. Water enters the dishwasher through a chamber which has a float arm connected to a small microswitch -this is the pressure switch. The concept is similar to that of the float switch for the aqua-stop system.
As the water level in the dishwasher rises, the water level rises in this chamber. Once the dishwasher and the chamber are full, water pressure trips this switch, closing the water inlet valve and the wash cycle then starts.
If the pressure switch doesn't trip, the water level continues to rise and this trips the overfill float switch. This closes the water inlet valve and starts the drain pump. Once the water level has dropped the dishwasher attempts to fill again, but the pressure switch remains closed and the cycle repeats - ad infinitum.
To check the pressure switch you will need the remove the left side panel (when facing the door) and a multi-meter to test the switch with. If you have the necessary equipment and skills to attempt this repair yourself (seems like you do) please let me know and I will provide the relevant details.
Regards,
BElectric
Posted on Feb 23, 2011
SHE45M05UC Bosch dishwasher
open the help booklet and follow the instruction if it is not working you can get replacement.
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
My bosch excel dishwasher has the following fault: start the cycle, water starts to fill but then check water light comes on and it then starts to empty again. Pump then keeps going. I have checked the...
this unit im sure has a water flowmeter that measures the water intake.. if this cannot read then the unit shuts down to avoid flooding..
it needs replacing... it is attached between the valve and the side tank or attached to the tank dependant on model...thanks
Dec 18, 2009 | Bosch Dishwashers
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher started, released soap, then nothing
Turns out the motor died. The good news is that it only cost $225 for the part and another $175 to install it. Aaah yes, the next machine will not be a Bosch.
Jan 15, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher starts, then won't move on from the "Empting" portion of the cycle
I am having trouble with my 5 year old Bosch. When I turn it on it is only on when the door is open. When I shut the door the computer believes it is off. I had a technician come and he tested the switch (which was fine) and said the problem must be in the computer. Then then quoted me $350 to fix it. I would rather buy the computer myself @ $120 and install it. What is your opinion?
Jan 14, 2008 | Bosch 24 in. SHV99A13UC Dishwasher
Bosch SHX43R55UC Dishwashers : Built in Dishwasher Logo
153 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
