A part of my adapter for my iPad seems to be broken. Cannot see any physical damage and it work just fine yesterday!
    Filmmaker:
    Uploaded 5 video answers.
  • 88 Answers
It probably burnt out. Its a power supply and the do go out. You can probably get it covered by the apple warrantee.
Posted on Jan 18, 2013
How to replace I pad 2 broken screen
Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
Good Luck.
Mar 01, 2015 | Apple iPad 2
My ipad wont charge or come on
it has to be on for your pc to read it,
you need to charge it but sounds like your ac adapter is dead or the charging port on the side of the ipad itself
plug in the adapter then move the cord around to see if theres a break in the wire inside the cord, and move the plug up and down where it connects to the ipad (push it in and out and side to side)
if that dosen't work take it to the apple store and they'll check both for free
Aug 22, 2012 | Apple Hard Crystal Back Cover Clear Case...
What could be the problem if the power does not come on?
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
Jan 23, 2011 | Nintendo Wii Console
My Inspiron 15r is not allowing me to use it. I was dropped slightly yesterday, a little over a foot, but looks physically fine. Sounds normal too. When I turn it on, it starts booting up normally, but...
Hello
The problem you defined shows that the windows gone corrupt, the cause may be due to hard drive or just data lose.
The quick remedy is re-installtion of operating system, hopefully it will works otherwise i am afraid the hard drive may physically damaged. which will also repaired if shock is low intensity.
Good Luck
Dec 15, 2010 | Computers & Internet
Wii won't turn on
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
good luck .
rate please !
Mar 23, 2010 | Nintendo Wii Console
My wii will not turn on, i have everything plugged in the rite spots, it was working just fine the other day, this is the second time this happend . do u know why?
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
See the following webpage @ Nintendo for more information:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Oct 21, 2009 | Nintendo Wii Console
Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Apr 15, 2009 | IBM ThinkPad T43 Notebook
Sony VAIO VGN-A690 not powering up
Press and hold the power button for about 20 seconds and then press the power button again. If your notebook is set to standby or hiberbate it may have lock up the computer. Hope this hepls
Feb 01, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
