Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool error code C6 - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
How do I reset my whirlpool Cambria dryer showing a c6 error code
Unplug it. wait 45 minutes then plug it back up. It should clear all codes.
Nov 07, 2016 | Whirlpool Dryers
Aeg lavamat error code c6
Found this on the following forum
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/aeg-lavamat-86741-error-t47666.html
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
