Question about Samsung DVD-P241 DVD Player
Samsung dvd won't play disk
Last week dvd player worked, today when i put a dvd in, it acts like it is loading, then message on tv screen saying to check disk, this disk can't be played....... gee it played in the same dvd player last week. whats up with this? please help with this problem, thankyou
  • anneenste Feb 21, 2009
    I get the message "This disk won't play. Check disk". Have used only a few times. Hope this problem can be resolved. Thanks.
  • Anonymous Mar 23, 2009
    Got the same problem with not being able to play disc that was previously able to be played.
  • 3130 Answers
SOURCE: samsung dvd-v4600
sounds like you need to clean the laser lens. Try using a disc cleaner first and if that dosent work then take aprt and find the laser lens, take a clean q-tip and put a little alcohol and swab the lens very carefully Good luck
Posted on May 09, 2006
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
  • 31 Answers
SOURCE: doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Posted on Mar 06, 2008
SOURCE: Samsung DVD-VR357 Won't play ANY DVD's
I took mine back today. I give
Posted on Mar 14, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Feb 16, 2014 | Sanyo Televison & Video
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
Mar 13, 2010 | Samsung DVD-V8600 DVD Player/VCR
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
When ever a disc is put into the ch300 I get a loading message
The laser lens could just be dirty, or it could be on it's last leg.
I'd recommend cleaning the laser first, laser replacement would cost more then the machine itself is worth.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Sony DVD player DVP-NS700H unable to play DVDs.
the dvd player lens damaged. -please change it with good technician
Sep 21, 2009 | Sony DVP-NS700H DVD Player
Wrong disk?
is the dvd multi region can it play disks from other countries if not find the codes for it by searching the name of the dvd player eg samsung unlock codes ........hope this helps
Jul 17, 2009 | NexxTech N600D DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
I have the same problem. How do you reset the unit?
Jan 09, 2008 | Samsung DVD-VR357
Samsung DVD-P241 DVD Player Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
