Question about ASUS P5RD1-VM Motherboard
I have an emachine w4630 notebook. i can't find the cmos battery which needs changed. do i have to to take the back off my computer?
  • 64 Answers
I do believe you may have to partially disassemble to get at battery. I have found the manual on line that you can download at the below address:
http://www.manualnguide.com/dl/9176/
the manual shows you where battery is located and how to change it.
took a bit to find, please be so kind as to take the time to rate this answer. good luck and thanks
Posted on Jan 27, 2009
E625 replace cmos battery, where and what type
inside the computer you will see a small circular silver watch battery thake this out and put it back
Nov 06, 2013 | eMachines E625 E725 laptop notebook PC LCD...
E732Z bios password problem
Try to leave it blank and hit Enter or if is not work,you need to manual reset your cmos battery to remove the password. feel free to ask.
Jan 22, 2012 | Acer eMachines E7254520 Notebook PC
How do I restore bios?
If all you have done is change the CMOS battery then the BIOS should be fine but it will have been reset to default settings which may have changed the Boot device and / or boot sequence.
Go in to the BIOS setup when you power on the computer and check that you have your main hard disk drive set as the main boot device.
Jan 13, 2012 | eMachines T3508 PC Desktop
How to change cmos battery
It's quite simple. First of all you have to turn off your computer and unplug all device cords from the back. Lay the computer facing up on the floor/table. Now, you have to locate the CMOS battery (It's similar to a watch - a little bigger though). It is on the motherboard held on by thin metal tabs. Some computers have the battery flat against the board while others have it in an upright slot. Use your fingernails to remove the CMOS battery and gently lift the metal tab. It is so weak that it can break easily. Do not lift the tab all the way or pull it off. Take the fingernail and place it under the battery in the casing and easily lift it up then pull it out. The last thing you have to do is replacing the panel and plugging in your devices.
I hope it works! Have a nice day!
May 18, 2011 | E-Machines M5105 Notebook
CMOS checksum bad Press f1 to run setup Press f2 to load default values and settinss Keeps comming up on star up
Your CMOS battery may be dead. That is the watch style battery on your motherboard. Choose f2. If the problem persists, change the battery
Feb 28, 2011 | E-Machines eMachines Desktop PC
Where can i find the cmos battery on emachines 420 desktop?
The cmos battery is located on the motherboard, and is easy to see,
its a big flat watch battery.
Look around on the motherboard for it, and there is a little clip somewhere around it that you need to push back to release the battery.
You should touch and hold the frame of the computer with one hand while you remove the battery, if you don't have a anti-static strap.
Feb 13, 2010 | E-Machines eMachines Desktop PC
Why won't new PNY DDR memory work in eMachines W4630?
Read your manual, as there website does not offer it just driver downloads.
Also, just because it is the same kind does not mean it will work.
That is why most MFG of motherboards have a quality vendor list
for memory. There are thousands of people who can't get some mfg's memory to work with there systems when the specs are the same.
But I would go with what Ultim said and there might be a slot limit.
Mar 20, 2009 | Computers & Internet
Cmos battery is dead
you will need to open the laptop from the bottom the battery is on the boare very simple to replace it could be one of two batterys ffc4efc.jpg the second battery is incased in yellow or blue plastic with to wires helping it to sit in the conputer better
Jan 25, 2009 | ASUS P5RD1-VM Motherboard
Emachin
Sometimes this problem happens when your CMOS battery already dead. Replace the CMOS battery and run F4 to setup the date and time. Save it and you back to business.
Mar 27, 2008 | Dell (E210882) Motherboard
ASUS P5RD1-VM Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
