Question about Electrical Supplies
Ducar 11kva 15 hp
Manual hi we got a ducar 11kva 15hp gen and didnt get a manual dose any one know were we can find one from
3 Suggested Answers
SOURCE: Had a DUCAR 11kva generator
You just need a new voltage regulator - a quality one
Posted on Jan 03, 2012
  • 6468 Answers
SOURCE: 15hp briggs
the only timing is the key on the flywheel to crankshaft i set the valves to .006 turn the engine till one of the rocker arms opens a valve then set the other one then do the same to the other valve those engines are known for valve seats falling out let me know if that's the case i can guide you to that repair
Posted on Apr 04, 2012
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
How to set throttle speed ducar genset
move screw of speed regulator on the top of the carburator clockwise
May 01, 2014 | Electrical Supplies
WHAT PUMP SEAL IS ON THE WHISPERFLO 15HP
i assume this is a 1.5 HP scp catalog SPG- 60-1000 about $7.43 (check under poolcorp)
Jan 14, 2014 | Pentair Whisperflo 15 HP Pool Pump WFE6...
Where is the alternator located on husqvarna lt140 dose not charge
Most gens are located under the flywheel. Need to remove flywheel to access gen. I would test to see if gen is truly not charging first before proceeding. A simple volt meter will check charging.
Apr 10, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
15hp briggs
Apr 02, 2012 | Briggs & Stratton Garden
I got a 90 cc ducar dirtbike and it wont idle right keeps on bogging out ,,what 's wrong with it
Try draining the carburetor. Water may have built up in the float bowl. Install a new spark plug.If draining and a new plug dobn't help, remove the carb then remove the float bowl and clean the carb with spray carb cleaner.
Jun 06, 2011 | Suzuki Tempter GR 650 Motorcycles
Had a DUCAR 11kva generator new, got it in Feb 2010. Yesterday, the voltage was not constant at 240, but was bouncing around 100v - 150v. As I am in warrantly, how do i get it serviced / looked at. ...
Sorry cant help with the servicing but Im looking at buyin one too? Hows it run over the last 18 months for you? want to run my Mobile Spitroast Van off of it.
Anyfeed back would be good. Oh and also if you find out about the Servicing thzat'd help too :o)
Greg
Jun 06, 2011 | Sport & Outdoor - Others
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
