Question about Coleman Mach 15 Air Conditioner
Need fan # and capacitor # for model 8333c876/serial # 060612272
2 Suggested Answers
SOURCE: Model No. 8333C876, Serial # 070512361: This unit
Coleman Mach Model No. 8333C876, Serial number 030508618. I just bought a 2005 Jayco Popup Camper with this unit on top. Both Low and High Fan controls work OK. when I turn the AC knob to High Cool, it will blow cool air. then after about 2 minutes, it seems to power down to a slow blow and my propane alarm begins beeping once per sec. Not sue if its related to the AC unit or the alarm. itself. Hopefully someone can decipher a solution with this description.
Posted on May 04, 2010
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
Model No. 8333C876, The Fan keeps freezing up. Is there a way to fix it, without buying another one ?
Hi, if by freezing up you mean that it wont turn, then I suggest maybe the bearings are out of lubricant. You may be able to disassemble the fan motor and regrease the bearings, or maybe replace the bearings, They are not very expensive, It will take about an hour to replace the bearings. have fun regards
Feb 24, 2011 | Heating & Cooling
Where i can find capacitors for hunter ceiling fans in Miami
Hello ...what leads you believe its a bad capacitor? I would need a more detailed explanation...however if you want to just replace it as a process of elimanation you can get all types and variations of them at almost ALL appliance stores and outlets ...be sure to have EVERY detail and info from the one you are replacing or call ahead and take it with you also fan model serial and brand name with you ...a reply would be appreciated
Feb 14, 2011 | Hunter 28096 Westminster 52" Ceiling Fan...
Blower fan in the inside unit tries to turn on but wont. It can be turned manually and air conditioner comes on and runs fine. The " squirrel " cage spins completely freely and is not sticky or jammed. Is...
Sound more like the cap, but if the motor is raging hot, it could be the motor, another thing it could is improper voltage although less likely. But Goodmans/ do have this weird fan relay issue were they just bite it some times. I would say its either gonna be your fan relay or capacitor, if you don't have a meter i would just go to Johnstone or whoever is you local supply house that handles goodman and ask for the fan really and the capacitor, bring your model and serial numbers, the fan capacitor is likely no bigger than a 15mfd and no smaller than 5mfd but they will be able to know, it will probably cost you 30 dollars max most likely around 15.
Oct 01, 2010 | Goodman Heating & Cooling
Electrolux split AC 1.5 ton inside fan working.But out side compressor fan stops after two or three rotations.
The 2 most common issues are a freon leak or the outside unit fan start capacitor goes out. It's more likely a capacitor issue. They fail regularly, especially when it's hot out. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Mar 21, 2010 | Heating & Cooling
Model#SRCF30U01D. Serial#920-629-3049.
Are the wires going to capacitor correct. You have two sides to the capacitor one side is compressor or herm as stated on top the fan. should have one wire only on fan side then two wires to the common side and one wire to herm side. trace out the wires I'm sure it's electrical and make sure you can see that it does in fact have a dual capacitor. Turn off all electrical supply before even touching this as you are around some big voltage. I do this everyday and I won't even get close unless I pull the safety disconnect on the side of the house. Get back to me and can help further. Ken
Aug 21, 2009 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
