Phillips c785 eco power comes on and switches it off
As soon as i turn the stereo on the eco power light comes on and the stereo switches off
3 Suggested Answers
  • 8457 Answers
SOURCE: Our phillips tv 100hz digital scan 29pt9418/79 won't power up
Yes,it about 90% of the times,it the power supply board.U can look around the power supply board for puff up bulge capacitors,replaced these caps will get ur power back.10% it ur Tuner signal board.If find no defective caps in ur power supply board.Tries websites Shopjimmy.com.Ebay.com to buy ethier refurbish power or tuner boards for the replacement.
Posted on Apr 04, 2010
  • 689 Answers
SOURCE: manual for phillips fw 3996 stereo
The echo effect has to do with the surround functions, You might be able to down load a manual for it, From ,Manuals Online.Com, For no charge,
Posted on Nov 05, 2012
Manual for phillips fw 3996 stereo
Nov 05, 2012 | Philips FWC780 Shelf System
My Fisher & Paykel intuitive eco washing machine starts the drain pump as soon as the power is turned on and continues pumping when no water present. It also displays "help, i need water" at...
Hi - this is a strange one - I could be wrong here but I think that theres two likely possibilities for you - first is the motor controller board could be faulty - it may have a short on the switch ic for the drain pump - the other is there maybe an air lock or blockage to the pressure tube - remove the display panel to access the clear tube - unclip it & blow into towards the bowl to see if theres a blockage.
You say as soon as the start switch is pushed the pump runs continously? or does it come on as soon as the power button is pushed? either way I think the controller maybe faulty - haven't come across aything like this one before...
Cheers
Aug 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I recently replaced my stereo with an after-market stereo and AMP. Since then I have power to the radio and all lights and interior after I turn off key and if headlights are on. I have checked radio...
did you wire the accessory power switch wire to both the stereo and amp, its a wire that turns off the devices as soon as the car turns off.
Jun 21, 2011 | 1999 Dodge Ram
What does the A/T eco switch do in my 2002 forester XT
It seems to turn the Eco light on in the dashboard. It doesn't really affect anything in the ECU of the car. Its used to show you if you are driving economically. Accelerate hard or go over 110 km/hr and the light will turn off even if the switch is on. The hold button keeps the car out of first gear so it will take off in 2nd and will try to change to 3rd or 4th as soon as possible to stop sliding on snow or ice. Hope this helps.
Jan 01, 2011 | 2002 Subaru Forester
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Apr 04, 2010 | Philips 26PF9966 26 in. LCD Television
My stereo is not coming on.. the time will illuminate when i press the display button and the lights behind the buttons will come on but will not turn on.. the cd will eject as well but thats it..
Sounds like the fuse for the switched power has blown. The stereo has two power inputs -- one unswitched, called "memory" because it lets the stereo remember your presets, and one switched, just called "power"
It should let you see the time, eject a CD, etc all when the car is turned off. Since the fuse for the main power line is blown, the stereo thinks the car is turned off all the time.
Feb 13, 2010 | JVC Car Audio & Video
Panasonic SA-AK27 Bookshelf Stereo - Setting The Clock
Have you put on the eco mode? try this: power on the unit, click on the eco button, until the unit will display "normal"
Jul 07, 2009 | Panasonic SC-AK27 Shelf System
Car stereo
First make sure you haven't turned the dash lights down so low that you can't tell that they are on. After that look for a wire coming from your headlight switch that is disconnected. Your headlight switch is also a "dimmer" switch and a separate power wire is probably required to operate this dimmer switch connected to your dash lights (including the lights in your stereo) you have probably ran this variable wire to your stereo and inadvertantly disconnected your dash lights.
Dec 23, 2007 | Car Audio & Video
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
