Question about Samsung RB2155 Bottom Freezer Refrigerator
Samsung RB215 refrigerator and freezer not staying cold/frozen
Our ice maker stopped working-now our refrigerator and freezer are not staying cold/frozen
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
SOURCE: Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Posted on Jun 10, 2009
  • 212 Answers
SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
Posted on Jun 24, 2009
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
woodchuck789
  • 4066 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Water do not get cold it stay room temperture and stay warm.
Its faulty compressor if freezer section is also not cooling.
But if freezer section is working fine,then problem is confirm defrost assembly.
repairclinic.com
partsselect.com
These will help.
Thanks,.
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Freezer light blinking Ice maker not making ice freezer not as cold
sounds like ur freezer is in alarm due to not being cold enough and wont allow the ice maker to distribute water to be frozen into ice u should have a fan behind the back panel inside the freezer make sure it is working and the coil underneath it is not frozen solid if the fan isnt working then check and make sure it has power if it does and the fans not running then replace the fan and this should get ur freezer working again but if the coil is frozen and the fan is running then u may have a bad defrost element that runs through the coil it is black u can test it by taking the wires off it and checking continuity thru it if it has continuity then its ok if not then it needs replacing
Mar 01, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker won't worker - freezer too cold
Switch the line to the hot water facet and turn down thwe thermostat in the unit.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker stopped making ice and freezer side not staying cold
Check that the circulation fan at back of freezer is running when unit is calling for cold.
Mar 11, 2009 | Samsung Refrigerators
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung RB2155 Bottom Freezer Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
