Question about Coleman Mach 15 Air Conditioner
Need to know what fan motor is used in the model 8333c876. ac apparently has a bad fan motor
Breaker trips inside rv. not using generator. also plugged into 50 amp service
  • 127 Answers
SOURCE: Need fan motor part # for Coleman RV AC mod # 8534B876 2 speed
The Motor that you are looking for is part #14683109. This is the coleman part number and you should be able to contact your local RV Repair facility and give them this number and get the motor. Hope this helped.
Jeff
Posted on Jun 29, 2009
  • 127 Answers
SOURCE: how much generator do I need?
On average, a rooftop unit with pull 14 to 16 amps depending on the ambient temperature. I am not sure how big your microwave is but we will assume 1000W. The TV really doesn't pull that much. So, you have 16 amps at the Air Conditioner, 8.5 Amps at the Microwave and we will say 5 amps at the TV. Lets not forgot the converter for the coach which pulls 3 to 5 amps on average. Add all of these amps together and you have 34.5 on the high end. To get the size Wattage of generator needed to run 34.5 amps, you take 34.5 and multiple it by the electricity source, in your case 120V. That means that you have 4,140 Watts of power to be used max. I think that with a 4000 watt generator, you will be fine. You may be able to go a little bit smaller if your microwave is not that large. To find the amps of the microwave that you have, take the wattage and divide it by 120. That will give the average amps that it pulls while running.
Hope this helps,
Jeff
Posted on Jul 04, 2009
  • 63 Answers
SOURCE: RVP 8000 Series Compressor wont stay running
I do not advise to repair most. Hand over in the service centre.
http://heaters.agilityhoster.com/
Posted on Aug 10, 2009
  • 53 Answers
SOURCE: A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
Posted on May 16, 2010
  • 587 Answers
SOURCE: air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Jul 28, 2010
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Why does the breaker keep popping when I turn on the air conditioner in my rv
The breaker will trip if the electrical draw or load from the ac unit exceeds the limits of the breaker rating. This can happen if the ac unit is getting old or has a maintenance problem which causes it to use more energy than it is supposed to. Try connecting a loaner AC unit or rental from your RV dealership to see if the problem is resolved by that.
Jul 25, 2010 | Yamaha 2500 Watt Industrial Inverter...
Compressor is blowing breaker, fan comes on. Ac worked fine last season. when trying to go to any cool setting, compressor will actually stall generator, or trip breaker if attached to house
You have a faulty start capacitor. The capicitor helps start the motor ... since it is not doing its job, the motor draws LOTS more power from the line popping the breaker. Have your professional RV service center service your AC.
Thanks for your interest in FixYa.com. Please remember to evaluate this response.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
Air Conditioner trips the 110v breaker, only when the outside temp is above 90 degrees. Unit has been checked several time and the circuit board has been replaced, but has fixed the problem of tripping the...
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop rv air conditioner doesn't work - what can I check myself without taking the rv to a repair place? will any air conditioner repair place do repairs or do I need to use an rv place?
I'm assuming when you say 'doesn't work' you mean 'nothing comes on,' i.e. the fan or the compressor.
If that's the case I would check for the AC breaker to see if it's tripped. Usually a 'tripped' breaker will look half on and half off, but sometimes it will be completely in the off positiion. Either way - it's usually because of a malfunction of the AC unit, so if that's the problem I would moniter it closely to see if it trips again. If it trips again in the immediate future I would then want to investigate the AC unit for the cause.
Also, some RV's have fuses in the AC circuit - so you could check and see if you have any fuses labled AC or AC control voltage. If so - you can usually - tell by looking whether they are bad or not. If that's not possible try replacing your 'AC labled fuse' with a new one of the same size.
I would also check your power supply (where the power cord to your RV plugs into) to make sure it is providing the proper voltage to your RV. Note: They also have breakers out on the box that you can reset. If they (breakers) appear ok - and you are at a RV park you could have the Park personel - check and to be sure the proper voltage is availible to your RV.
good luck!
May 03, 2010 | Dometic Rooftop RV Air Conditioner
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
