Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
I can't remove the retainer 931-900 in a price pfister kitchen faucet
  • Lee Rittiner
    Lee Rittiner Jan 10, 2015
    This is plastic. It has been replaced with the 941-711 a metal one. straight from PriceFister: How do I remove the retainer ring? You can order the retainer ring tool removal (950-047) or you can use a 1/2" iron to copper female copper adapter and a pair of pliers over the adaptor. Sounds like we have very old faucets. If you learned more let me know.
  • Lee Rittiner
    Lee Rittiner Jan 13, 2015
    I used Channel lock pliers {tongue and groove, I think} with no luck. I hit it with a penetrating oil and it came loose. I did chew up the top of the threads a bit. It made screwing the dome cap harder than before, but I was able to make it thread the plastic.
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
SOURCE: handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: kit. sprayer/hose
watch this http://www.pricepfister.com/about/diverter.aspx
Posted on Jul 02, 2009
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
How do you remove the handle to replace valve?
Unscrew top button.
Using a phillips screw driver remove handle retaining screw and work off handle.
If it leaks under the handle you need to unscrew the top cap, use a strap wrench to hold the body and tighten the brass retainer ring with an adjustable wrench. Or remove the ring to replace the cartridge.
Nov 23, 2011 | Price Pfister Marielle Kitchen Faucet with...
How to remove spray handle?
Remove the retaining nut under that should be a fitting with a small horse shoe shaped retainer chip. Remove that wit small sharp tool maybe a small mini screw driver and and it will come right off.
Feb 13, 2011 | Price Pfister Marielle Kitchen Faucet with...
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Sep 14, 2009 | Plumbing
Handle on faucet shuts off on its own
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
1,337 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
