Question about Maytag Atlantis MDE8400AY Electric Portable Dryer
How to remove control knob on maytag mde8400ayw timer
I need help in how to remove control timer knob
    President:
  • Maytag Master
  • 2,651 Answers
Youll need to "pop" the center of the dryer knob off, the outer mos part of the knobin which oyou turn is a false front, that actually locks the knob onto the timer shaft, use a small screw driver to pry it off
Posted on Jan 25, 2009
Maytag dryer won't shut off when load is dry. Model mde8400ayw
Very highly likely you will be needing a new control/timer.
Sometimes these are easy to replace, sometimes harder.
God bless your efforts.
Dec 05, 2017 | Maytag Dryers
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
Will not complete spin cycle
Thank you for your question Maytag is famous for there timers going out you did not say what model it is but if you remove the 6 screws from the back of the control panel you will have access to the timer sears can get you a new one it has plug in connections remove the control knob and the screws that hold it in be vary sure to unplug it first safety first always
Jun 21, 2012 | Maytag Washing Machines
I have a Maytag washing machine MAV3905AWW. I would like to replace the timer. How can I remove the knob?
Hello, To remove the knob on this unit you need to push the knob in and on the back side of the timer in the center is a white plastic pin that you have to hold with a small screwdriver while pulling the timer knob off. If you look at the back of the timer while pushing and pulling the knob in and out you will notice the plastic center pin moving in and out.Just hold it out and pull the knob off. Hope this helps.
Jun 06, 2011 | Washing Machines
The timer control knob seems to be free wheeling & no longer clicks when you turn it. We looked at a web site that sells parts & think it might be the timer, does that sound right?
Hi, It has something to do with the timer, that I can tell you.
Some timer knobs must be pushed in to rotate them, Others timer knobs must be pulled out. And, of course, some timers you just turn.
If you can turn the knob and it spins but the pointer on the timer does not spin. It is the knob assembly itself. Possibly just loose.
If you can turn the knob and the pointer on the timer rotates freely without any type of click or resistance, The timer is failed.
If it is the knob, you should be able to pry off the center piece with a very small screwdriver and check to see if the know is loose.
Maytag has used different types of mechanisms in their timers. So good investigation will help in the determination.
If the symptom you are experiencing is that the machine doesn't run. Other things can be the cause of that. An inoperative door switch will render a clothes dryer silent.
I hope this helps,
Good Luck,
Mark
Jan 16, 2011 | Maytag MDG9606 Dryer
Dryer works great but will not stop running on its
HI. this will occur when there is a fault within the timer control module. have this damaged timer replaced asap. this will fix this issue you are experiencing at this time.
Aug 21, 2009 | Dryers
Maytag Washing Machine Cycles Out of Sync with Dial
ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Feb 27, 2009 | Frigidaire FWS833A Top Load Washer
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
May 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Open Questions:
Only the extended tumbler option works. I have similar Maytag dryer model MDE8400AZW.  On any of the dryer settings, the dryer does not work (I will pull the handle and hold, the "damp" indicator light turns on without starting the dryer). I know it's not the motor because when I turn on the switch for extended tumble and turn my knob to extended tumble, pull the handle, the dryer will begin rotating as if nothing is wrong. I know it's not the door problem, because when I use my finger to press the door close "button" the interior light turns off and the extended tumble still works even though none of the other settings work. One strange problem I had was the turn switch.  Periodically, I would turn the setting to any random setting, try to turn on.  Repeating this at times would start dryer.  At first, I would only had to do this one or twice before working.  Later, I had to do this more and more.  Now it's not responding at all. I don't think it's the fuse because when I tried pulling the plug on the fuse, the extended tumbler doesn't work either. My first instinct was to replace the knob (I have not done so yet), but why is the extended tumbler working (every time) and nothing else? My guesses are 1. Knob is problem after all,  2. something is preventing any cycle that requires heat (maybe a thermomitor problem) One last thing, I've taken out the thermomitor (originally thinking it was the fuse).  When I shake it gently, I hear rattling metal pieces.  I'm not sure if this is normal or if it's broken.  I believe it's the maytag part 33002742.
Jan 05, 2009 | Maytag Atlantis MDE8400AY Electric...
Maytag Atlantis MDE8400AY Electric Portable Dryer Logo
483 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
