Question about Coleman Mach 15 Air Conditioner
Need to know what fan motor is used in the model 8333c876. ac apparently has a bad fan motor
Model # 8333c876 serial # 060612272. Have replaced circuit breaker but breaker continues to trip. Bad fan motor or short in wiring? Breaker trips after ac being used on fan only.
  • 63 Answers
SOURCE: RVP 8000 Series Compressor wont stay running
I do not advise to repair most. Hand over in the service centre.
http://heaters.agilityhoster.com/
Posted on Aug 10, 2009
  • 588 Answers
SOURCE: air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Jul 28, 2010
  • 16 Answers
SOURCE: My coleman Mach Rv air
There should be an overload protection device in series with the low voltage wiring(t-stat wiring) Is it resting on the heat strip or too close to it? It is a saftey device to shut off the heat strips if the fan quits or a fire in the heat strip section. check that or by pass it, if it stays running then ur thermal protector is bad, couple bucks at the parts house.
Posted on Nov 06, 2010
motor1258
  • 6674 Answers
SOURCE: the ac trips the breaker in the camper when the
Check that incoming voltage is up to specs at AC unit control box ( 110-120VAC ), and if good, I'd suspect start capacitor for compressor is defective and needs replacing provided compressor is good. Usually a new capacitor is required in most cases. Please don't try changing it yourself if not experienced in that area, as capacitors can give a very high voltage shock, even with power off.. Don't forget to turn breaker off to power source before working on it.
Posted on Jun 29, 2011
Testimonial: "thanks the capacitor was bad."
  • 114 Answers
SOURCE: high side of fan motor trips breaker , low side
So, the condensor fan motor trips the breaker? Have you checked the run capacitor? It can easily be checked with a multimeter.
Posted on Aug 03, 2011
America Standard heat pump model WCy036- turns on but fan on blower not working???? Any manual anywhere I can download
While I do not know about manual the fan is located on top of unit and goes bad the check s simple if you know electricity first pull breaker on unit using a multimeterrible sett on volts push leads into 2 wires going to fan motor about replace breaker staking clear if meter show
voltage pull breaker remove meter an you fan motor is shot no voltage freon or other technical problem call AC GUY if fan motor dead call refrigeration supplier name model an serial number simple unbolt takeoff fan and two wires to replace ALWAYS PULBRE
AKER BEFORE working on any electricAl applia
Aug 16, 2015 | Heating & Cooling
Ok I have replaced the therm,coolant temp sensor and replaced the 40amp fuse the keeps blowing,causing coolant fans to not work,causing overheatin. It does fine,fans work and no overheating until I turn on...
If the A/C is on the same circuit as the coolant fans, then the A/C motor is going bad and drawing too much current. A local shop should be able to test the motor for a small fee, or, if you know how to use a multimeter, you can check the motor's resistance for shorts. You'll need to know the original motor specs before testing; the motor model #, maker, etc., should be somewhere online, or available from the maker.
Jun 13, 2014 | Cars & Trucks
Just had AC tech charge $257 to replace capacitor on carrier 38ckco48300. tech also stated condenser fan motor may have been damaged with replacement cost of $500. can a condenser fan motor for this unit...
I don't know what part of the country you are in, but here in Okla. a condenser motor can be bought by the home owner for around $100. You should be able to go to any appliance supply house and purchase your own motor. Take the model and serial number with you, it may help. If you have a local carrier distributor, they should give you a users manual. Try your best to get a motor close the the same as what you have. Note the horsepower, rpm, voltage and take the fan blade with you in case you need a new one. Hope this helps. Mark
Sep 07, 2011 | Heating & Cooling
Samsung split ac mdl # u24a2qc, system is about 10 years old. outside condensor operates fine until warmest part of day, then the fan on the compressor unit cycles on and off repeatedly although the...
I would guess that the motor is pulling to many amps, it could be to small (not the horse power as should be), could be bad incorrect fan blade (to many blades or pitch on blades) over loading the motor. I have seen fan motors get to hot and stop from a dirty coil. Take a garden hose and a nozzle use a solid stream carefully watching the fins don't bend by high water pressure. Throughly clean the coil every inch or it. Hope this helps.
Jul 09, 2011 | Samsung Heating & Cooling
Model No. 8333C876, The Fan keeps freezing up. Is there a way to fix it, without buying another one ?
Hi, if by freezing up you mean that it wont turn, then I suggest maybe the bearings are out of lubricant. You may be able to disassemble the fan motor and regrease the bearings, or maybe replace the bearings, They are not very expensive, It will take about an hour to replace the bearings. have fun regards
Feb 24, 2011 | Heating & Cooling
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
Fan is not working even i use air condition or heater no air coming out and i don't know which one to replace?
First check the fuse for the heater/ac fan. If the fuse is OK, you probably need a new blower motor. If the fuse is blown, replace it. If it blows again, you could have short in the heat/ac control computer, or the blower motor may still be bad. In this vehicle, the blower motor is probably less expensive to replace than the controller, and you can test the blower once it is disconnected by applying battery voltage to it (observe correct polarity). If it does not move when jumped directly to the battery, it is almost certainly bad.
Dec 20, 2009 | 2003 Acura 3.2TL
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
53 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
