Question about Frigidaire GLEQ2152ES Electric Dryer
What is the capacity of my frigidaire Gleq2152es0
Frigidaire Dryer GLEQ2152ES0 counts down almost in seconds.
Sounds like a board communication problem check and spray connections
Feb 18, 2015 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
My frigidaire dryer GLEQ2152ES0 runs but no heat and the lights all blink
bad heating element check with multi meter first? check ur thermostats also. lastly may be not getting full 240 at the terminal block
Jun 09, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidaire GLEQ2152ES0 not heating -- How do I check and change the fuse?
use a ohm meter, remove 1 of the wires from fuse, take your both leads from your meter and touch each one on the fuse, If you are showing OL, means its bad, If its giving you a reading then its something else.
Jul 27, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES0 GETTING TOO HOT
Most likely a bad temp control or a broken fan. The control is mounted on the blower housing. To access READ MORE
Jun 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
FRIGIDAIRE GLEQ2152ES0 DRYER DRUM WILL NOT TURN
You need to check the motor isn't bad which is possible. All of what you have stated is possible. You are going to have to check out each and every one until you find it. But all three can cause it.
Apr 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
21 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
