Question about Danby DWM5500 Front Load Washer
Danby front load washer Will not spin motor runs
The spin cycle does not work, will not spin at all ? Front Load Model DWM 5500W. Is there a belt or is it the motor it will wash but will not sping at the end cycle.
    New Friend:
I just had the same thing happen.
Clean the lint trap at the bottom left. Use a coin to unscrew the cap, then unscrew the filter that is is front of the pump. If the water is not ejected, then the machine will not spin faster.
Posted on Dec 18, 2009
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Posted on Feb 07, 2009
SOURCE:
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
Spin cycle does not appear to complete it's cycle/ drain all the water. Is this a belt or motor issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Amana ALW480DA Top Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
SPIN CYCLE
need more information is it top load or front
Nov 19, 2007 | Maytag Neptune MAH5500B Front Load Washer
Danby DWM5500 Front Load Washer Logo
921 people viewed this question
Top Danby Washing Machines Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
