Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Neff washing machine no waer getting in after fitting in
Ater fitting neff washing machine w5320xogb water will not go into my machine
  • Canon Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machineneff washing machine no waer getting in after fitt - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
Neff washing machine not spinning. Fine yesterday, slightly funny noise and now drum not moving on wash or spin! Any clues?
Could be worn Carbon brushes on the motor.Check belt has not fallen off though...some Neff you need to buy half motor to fit new brushes as it comes this way, perhaps a good test is to blow ut any dust next to the brushes this may allow the motor to Briefy run long enough to tell if brushes are worn ..Half motor cost to buy - 60 GBP......Happy new year...
Jan 02, 2011 | Neff Washing Machines
NEFF WASHING MACHINE
Error code e 10 means no cold fill.
Ensure that the water getting to the machine from the water supplies at the back. Check that the hoses are not bent or kinked and that the water tap is opened.
Try cutting power to the machine for ten minutes to reset the code.
If that does not work, then it is usually a faulty inlet valve stuck on closed on cold water.
Feb 27, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Water inlet hose not letting water through to the machine
that's probably a flood-safe type hose ... most of them reset after you remove it and re-install where it connects to the faucet, but you have already swapped it . try removing it and reinstalling it , then turn water supply on slowly
Jan 16, 2009 | Neff W5340X0 Washer
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
