Question about Aiwa Audio Players & Recorders
Cx-nav800u I think I may have a blown fuse somewhere in my aiwa boom box I need to know how many fuses does the radio hold. I have already took out three is there any more?
  • 4234 Answers
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Posted on Aug 14, 2008
SOURCE: jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Posted on Oct 21, 2008
  • 512 Answers
SOURCE: my eagle vision radio is not worrking i need the owners manual
check fuse 2 and 13 in the fuse block inside the car
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: Fuse box diagram
There are two fusebox diagrams, one is your main fuse box.
- Main Fuse Box - Pop you're hood and it will be on the left, it will have different labeled squares with amperages on it.
- Panel Fuse Box - It's on the driver side to the left of the break pedal. I'd invest in a manual I can't tell you which is which.
Posted on Dec 10, 2008
  • 740 Answers
SOURCE: where is fuse box located on 2000 galant i think
under the dash or on the side of the dash if not there its under the hood or behind the glove box
Posted on Jan 06, 2010
What is the fuse number for radio in 2007 vw jetta automatic
Not sure which fuse it is, but it will be in your manual in the glove box. Your radio may need reset, though. Volkswagen has anti-theft radios and in some instances you will need to have them reset. Your manual in the glovebox will tell you if your radio has this feature.
Apr 04, 2015 | 2007 Volkswagen Jetta 2.5 Sedan
2004 sunfire
The best advice for a quick solution is for you to look at your fuse box. It should indicate right there what fuse is for the radio. If not, look at all of the fuses and replace the one that is blown.
Aug 31, 2014 | JVC AM FM CD DET FACE CAR STEREO
I got a malibu 2010 my radio fuse is blown i do not know which box it is in to change it
The radio fuse is in the fuse compartment located on the passenger side of the console. Remove the cover on the console and then remove the fuse box cover, search out the radio fuse and inspect to see if it has blown.
Jul 05, 2014 | 2010 Chevrolet Malibu LS
2007 Jeep Wrangler radio not working at all
yes there is fuse for radio also if this is after market radio on stereo is a fuse on baback by wires there is also fuse box in engine compartment there too is a fuse for radio i belive its a mini fuse check manual for numbered location pull out see if its blow //my jeeep did that too radio fuse was fine but iidecided to look under hood and boom there it was a blown mimi fuse replaced radio all back on
Mar 20, 2014 | Car Audio & Video
Aiwa mod. CX-ZR774 System will not power up
I assume that the Aiwa controls the other components, such as a CD changer. If these units are plugged into the rear of the Aiwa, then they may not be receiving power due to an auxiliary switch being off, or a bus breaker being blown. Breakers are on the back panel of the unit. They have a black thumbscrew that turns out counterclockwise. Take the fuse to Radio Shack to confirm if it is good or not, and good a new one if not. If the components are not connected to the Aiwa, then I have the ask the stupid question of are they plugged in, or is the surge protector that they are plugged into plugged in. Remember that even modern surge protectors have breaker switches, and may need resetting, especially after a snow or thunderstorm. Good luck.
Jan 27, 2014 | Aiwa Audio Players & Recorders
Radio Dead and already changed fuses that were not blown
Yes and fuses are tricky some don't look blown and they r, and some look blown and r not But to check the radio itself put a volt meter to the wiring connection on back of unit
Jan 02, 2014 | 2003 Chevrolet Silverado 1500
How Do I Reset Circuit Breakers in 2006 GMC Envoy?
Hi Michelle, I'm glad to help!
Michelle, Sometimes there is a hidden fuse box inside the vehicle somewhere. It could be behind the glove box, in one of the kick panels next to your feet OR even on the side of the dash behind the cover. You'll need to check with the dealer and give them your VIN number and have them see if there are more then just the under-hood fuse box. Because most likely you have blown a fuse somewhere. You check on the fuses boxes and I'll do some more research and let you know. Hope this helps and have an awesome day Michelle.
Jun 04, 2013 | Cars & Trucks
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Jan 30, 2010 | 1997 Acura RL
Fuse
you found the fuse box right?
There will be a diagram on the back side of the fuse box cover. Use it to identify which fuse belongs to the sound system.
If you don't know where the fuse box is, let me know.
If you still can't figure out the right fuse, give me the options that are in the box and I will let you know which one it is. thanks
May 16, 2008 | 2005 Saturn ION
How do you set radio stations on this thing
WHAT YOU DO IS PUT IT ON THE STATION YOU WANT THEN YOU HOLD THE PLAY BUTTON DOWM
Nov 18, 2007 | Aiwa Audio Players & Recorders
37 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
