Question about Frigidaire FEQ332E Electric Dryer
Dryer won't come one
It was working one day and the next nothing....it makes a buzzing noise when turning the on knob....did I mention it is 14 months old......any suggestions
  • 979 Answers
You may have a problem with the timer or something is keeping the motor from turning. It is fairly new still and still may be under warranty. If not under warranty, it should be quick and easy to fix. You are getting power to it or at least some power. Turn off both breakers to it and then turn back on. There may be a chance that it is only getting one leg of power.
Posted on Feb 03, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I turn the start knob and it just makes a buzzing sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer making a buzzing sound in the console but not running
Unplug the dryer.
Remove the rear panel.
Look on the exhaust vent for a failed fuse.
It will be narrow and about 1 and 1/2 inches long.
Remove the 2 wires and jump them together.
Plug in the dryer and start it.
If everything works OK replace the thermal fuse.
Feb 27, 2009 | Roper RES7646KQ Electric Dryer
Won't come on, just makes a buzzing noise when you turn on knob..
If it makes just a buzzing noise, Your motor has probably gone bad. If you open the doot and hold the door switch in then have someone hit the start button, Then spin the drum by hand and it may start. This tells you that the start windings in the motor are going bad. If this does not work then your motor has totally gone bad.
Jan 30, 2009 | Frigidaire FEQ332E Electric Dryer
Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Aug 14, 2008 | Dryers
Frigidaire FEQ332E Electric Dryer Logo
95 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
