Question about Whirlpool Duet GHW9150P Front Load Washer
My Washing Machine "Walks" Across the Floor, is there anything i can do to fix it? I HAVE THE SAME PROBLEM. THE WASHER IS ON THE 2ND FLOOR, FRONT LOAD WASHER WHILPOOL, AND HAS BEEN LEVELED SEVERAL TIMES. THE SCREWSWERE REMOVED FROM THE BACK WHEN IT WAS INSTALLED. IT SHAKES AND WALKS SO MUCH THE LIGHT BULBS IN THE HALLWAY SHOOK LOOSE. THANKS FOR ANYONE'S HELP.
  • CINDY9675 Jan 25, 2009
    WE ARE GIVING IT A TRY, YOU HAVE BEEN VERY HELPFUL. THANKS
  • melissa12298 Jan 26, 2009
    My machine is making a loud noise in the end of the wash and rinse cycles. We have leveled it out and now it is louder and rougher.
    President:
  • Whirlpool Master
  • 2,651 Answers
2 thing ifyou remove the lower acxess panel(3 screws acros the bottom) yo can look inside and make sure the 4 suspension/shock absorbers are in place. if they are yo can installa new product to minimze the shaking ofthe frontloading wsahers, reallly has improved performance on the machines ive tried it on.. http://www.apwagner.com/index.php?main_page=product_info&products_id=148095
Posted on Jan 25, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
My washer walks across floor in spin cycle, machine is level
what make is the washer is it a Maytag Neptune or a Samsung Neptune and does it looks like this pic below
Feb 11, 2013 | Washing Machines
Vibrates then starts walking across floor
LG washing machines are very finicky with being leveled, they must be 100% level, and squared up on all sides. Be sure to lock the nuts in place, once you level it, to where it needs to be. They are also finicky with certain floor surfaces, more leveling may be required.
Mar 30, 2010 | LG WD-16115FD Front Load Washer
Washing machine walks
The problem MAY be fixed. I went to http://www.fixya.com/support/t14304-washing_machine_walks_across_floor , made sure shipping bolts were out, then discovered nuts that clamp the feet were loose. They are now tight with unit re-leveled. Testing is in progress.
Oct 28, 2009 | Kenmore HE2 Plus Front Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Washer walks across floor no matter what problem.
FIRST OF ALL SCREW THE FRONT LEGS ALL THE WAY DOWN THEN TILT THE MACHINE UP FROM THE BACK MEANING THE BACK SIDE UP SET DOWN FIRMLY THIS WILL AUTOMATICLY SELF LEVEL THE BACK LEGS THEN UNSCREW THE FRONT LEGS TO MAKE LEVEL WITH YOUR FLOOR THIS SCHOULD FIX YOUR PROBLEM THANKS GLAD TO BE OF SERVICE
Feb 03, 2009 | Maytag Performa PAV2200
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
477 people viewed this question
Dan Webster
Dan Webster
Sal De
