Changing a Canon Mg100 Fine ink Cartridge - Office Equipment & Supplies
SOURCE: black not printing
Excellent solution. May want to run the maintenance clean head action from the printer menu on the printer and also print a horizontal line test page to make sure the heads are aligned properly.
Posted on Dec 26, 2007
  • 5 Answers
SOURCE: refilling of canon ink fine cartridge pg 41
Phew! Finally. This one works for my Canon MP140.
Follow all instructions completely or it won't work....
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Posted on Jan 14, 2009
you must buy a brand new cartridge do not refill your old cartridge and use it again it may cause malfunction of your printer..one thing you have encounter is " the cartridge is not recognized"
Posted on Feb 15, 2009
  • 214 Answers
SOURCE: help changing canon mp160 ink cartridge
There is button to press on printer to put heads in position for changing
Posted on Apr 23, 2009
reitann
  • 214 Answers
SOURCE: new ink cartridge still not printing
Try resetting and cleaning the printhead
Posted on Sep 24, 2009
How do I change the print cartridges?
  • Open the printer cover and prop it up with the support brace located on the right-hand side of the cover.
  • Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Mar 10, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon pc 941 copier cartridge issues
    Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
    Jan 25, 2012 | Canon PC-941 Copier
    How do i reset ink cartridge cl511for my canon ip2700
    1. Make sure that the power is turned on.
    2. Open the Front Cover.
    The FINE Cartridge Holder moves to the replacement position.
    3. Remove the empty FINE Cartridge.
    (1) Pinch the tabs and open the Ink Cartridge Locking Cover.
    (2) Remove the FINE Cartridge.
    4. Prepare the new FINE Cartridge.
    (1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
    5. Install the FINE Cartridge.
    (1) Put a new FINE Cartridge in the FINE Cartridge Holder.
    The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
    (2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
    Push down the Ink Cartridge Locking Cover until it clicks.
    (3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
    6. Close the Front Cover.
    Sep 20, 2011 | Canon Office Equipment & Supplies
    Changing ink and had some one take it out now have new ones and not sure witch one goes were
    Insert the black ink cartridge into the left slot of the ink cartridge holder and the colour ink cartridge into the right slot of the ink cartridge holder.
    Dec 07, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
    The following cartridges are compatible with Canon MP160:
    Canon PG 40 Black Ink Cartridge Black Ink Cartridge
    Canon PG 50 High Capacity Black Ink Cartridge
    Black FINE Cartridge, High Capacity
    Canon CL 41 Tri Color Ink Cartridge
    1 Cartridge of Cyan, Magenta, and Yellow
    Canon CL 51 High Capacity Color Ink Cartridge
    Color FINE Cartridge, High Capacity
    Nov 23, 2010 | Office Equipment & Supplies
    Help changing canon mp160 ink cartridge
    Apr 23, 2009 | Canon Pixma MP450 All-In-One InkJet...
    Price of catridge of cannon ip1300
    these are the cartridges used in 1300
    CL-41 FINE Colour Cartridge
    PG-40 FINE Black Cartridge
    click here for cl 41 prices
    http://www.google.com/products?q=cl-41
    Click here for pg-40 prices
    http://www.google.com/products?q=pg-40
    Let me know if you need anything else.
    Thanks,
    Ekse
    Mar 05, 2009 | Canon PIXMA iP1300 Printer
    Canon bjc-85 printer doesn't print anymore
    Have you tried changing the green carrier? That solved my problems with no ink.
    Dec 04, 2007 | Canon BJC 85 InkJet Printer
    Open Questions:
    112 people viewed this question
    k24674
