Question about Vestax Handy Trax Turntable
K 28.5 drive belt - Vestax Handy Trax Turntable
I NEED 3 NEW TIRES AND DRIVE BELT PLUS MANUAL FOR DELTA 28-540
Hello, Well, I can't help you with the tires and a drive belt you will just have to go to and automotive repair parts house for that, and work for the money for it, As for the manual, here is the website you need for the delta 28-540. chrisconnolly needs help with Delta 3 Wheel Band Saw on...
Dec 11, 2014 | Cars & Trucks
What is error 28
Precor Error 28, Temperature Too High Probable Cause 1. The lower PCA cooling fan is clogged.
2. The lower PCA cooling fan is inoperative.
3. The running belt and/or deck are badly worn.
4. The lower PCA is bad.
5. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Inspect the fan mounted on the lower PCA for dust/debris buildup. Clean if necessary, ensuring the fan spins freely. Some lower PCA's do not have a cooling fan and others may have the fan mounted on the underside of the lower PCA making it not as visible.
  2. The fan was free of dust or debris but does not spin. Make sure that the fan wiring is secure and properly connected to the lower PCA. If no obstruction to the fan and the wiring is good but fan still doesn't turn, replace the lower PCA.
  3. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions; compare the values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  5. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 28
Sep 13, 2013 | Precor C966i Treadmill C 966i
Frigidaire stackable model FEX831CS0 won't agitate or spin
Hi Kathy.
If the washer does not agitate and spin, then the most common problem is the belt: Washer Drive V-Belt (part 28 in diagram 1)
If you can manually advance to spin but the machine does not agitate, then parts that may need to be replaced are the agitator:
Agitator (part 11 in diag 1) or the agitator drive in the transmission:Agitator Drive (pt.2 diagram 2)
To replace the belt remove the assembly at front top of the washer held by two philips screws and clips. Here description of replacement procedure.
Here Diagram 1
Here Diagram 2
Regards.
Ginko
Nov 18, 2011 | Washing Machines
Frigidaire stackable W/D does not agitate or spin
Hi.
Here Diagram 1
Here Diagram 2
Regards.
Ginko
Replacing alternator on 2001 sebring..cant locate belt tensioner
The tensioner will be one pulleys that can be rotated on its armature to remove tension to the belt.
Removal & Installation 2.4L Engine To Remove:
  1. Disconnect the negative battery cable from remote negative terminal on shock tower.
  2. Remove the drive belt cover.
  3. Disconnect the wiring from the generator.
  4. Raise and safely support the vehicle.
  5. Remove the accessory drive belt splash shield and then remove the belt.
  6. Lower the vehicle.
  7. Remove the MAP sensor from the intake manifold.
  8. Remove the generator mounting bolts and the generator from the engine.
To Install:
  1. Install the generator and tighten the bolts to 20 ft-lbs (28 Nm).
  2. Install MAP sensor.
  3. Raise and safely support the vehicle.
  4. Install the accessory drive belt and splash shield.
  5. Lower the vehicle.
  6. Connect the wiring to the generator.
  7. Install the belt cover.
  8. Connect the negative battery cable.
2.7L Engine To Remove:
  1. Disconnect the negative battery cable from the remote terminal.
  2. Raise and safely support the vehicle.
  3. Remove the accessory drive belt splash shield.
  4. Loosen the accessory drive belt.
  5. Remove the generator lower mounting bolt.
  7. Disconnect the wiring from the generator.
  8. Disconnect the electrical connector from the A/C pressure switch and clutch coil.
  9. Remove the engine oil dipstick.
  10. Remove the generator upper mounting bolts.
  11. Remove the generator.
To Install:
  1. Install the generator on the engine. Loosely install the upper bolts.
  2. Install the engine dipstick tube.
  3. Connect the A/C pressure switch and clutch coil electrical connectors.
  4. Connect the wiring to the generator.
  5. Raise and safely support the vehicle.
  6. Install the lower generator mounting bolt and tighten to 20 ft-lbs (28 Nm).
  7. Install the accessory drive belt and splash shield.
  8. Lower the vehicle.
  9. Tighten the upper mounting bolts to 20 ft-lbs (28 Nm).
  10. Connect the negative battery cable.
Feb 03, 2011 | Chrysler Sebring Cars & Trucks
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
My belt tensioner pulley broke at the bolt that bolts to the bracket. I bought a new one and I was wondering if there was an easier way to replace the tensioner pulley other than removing both the upper...
You should only remove the drive belt shield if you raise the car. Below are step-by-step instructions per the repair manual. Drive Belt Tensioner
Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  3. Remove the drive belt shield at the right wheel well.
  4. Remove the drive belt.
  5. Remove the drive belt tensioner mounting bolt.
  6. Remove the drive belt tensioner.
To Install:
  1. Install the belt tensioner. Torque the mounting bolt to 21 ft. lbs. (28 Nm).
  2. Install the drive belt.
  3. Install the drive belt shield.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
Oct 30, 2009 | 1999 Plymouth Grand Voyager
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
How to install drive belts to 1996 nissan quest
go here for help
http://autos.groups.yahoo.com/group/villagerquest/files/
Item Part Number Description 1 — A/C Compressor Drive Belt Idler Pulley Adjustment Bolt (If equipped)
(Part of 8678) 2 — A/C Compressor Drive Belt Idler Pulley Tensioner Bolt (If equipped)
(Part of 8678) 3 8678 A/C Compressor Drive Belt Idler Pulley (If equipped) 4 8620 A/C Compressor Drive Belt (If equipped) 5 2E884 A/C Clutch Pulley (If equipped) 6 10346 Generator 7 10344 Generator Pulley 8 11719 Generator Adjustment Bolt 9 — Generator Locking Bolt 10 8620 Generator Drive Belt 11 6312 Crankshaft Pulley 12 — Water Pump and Power Steering Pump Drive Belt Adjustment Bolt (Part of 8678) 13 8678 Water Pump and Power Steering Pump Drive Belt Idler Pulley 14 — Water Pump and Power Steering Pump Drive Belt Idler Pulley Locknut (Part of 8678) 15 3A733 Power Steering Pump Pulley 16 8620 Water Pump and Power Steering Pump Drive Belt 17 8509 Water Pump Pulley A — Tighten to 16-20 Nm (12-15 Lb-Ft) B — Tighten to 33-37 Nm (24-28 Lb-Ft)
Mar 28, 2009 | 1996 Nissan Quest
Vestax Handy Trax Turntable Logo
46 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
