Question about LG Shine KE970 Cellular Phone
Problems with the phone backlight
The backlight is not working properly and when attempting to fix it i turned it off in the menu ... Now i cannot even view my phone display at all because the light is off .. any ideas?
La charge de battrie
Posted on Nov 29, 2008
  • kholio343434 Nov 29, 2008
    j'ai un problème à mon portable KE970, j'ai la ronde glisseur de centre ne marche pas sauf avec un code elle marche apres de l'activation de flash et positionnement et la battrie elle ne tient pas la charge plus que 8 heurs merci de tout j'attend une réponse sur mais questions avec mais salutations.
Get a hammer and smash it
Posted on Jul 13, 2007
SOURCE:
Slim psp no display/sound but green light on
Turn On your psp ress the directional button. If there is sound from the menu. I think you lcd backlight dead or the hardware conecction not work properly that make the lcd backlight died
Sep 03, 2010 | Sony PlayStation Portable (PSP) Slim...
My acer extenza 4420 backlight wont turn on
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Aug 31, 2009 | Acer Extensa 710TE Notebook
My screen went black yet under certain light i can see it very slightly is this fixable
There should be a property in your settings menu that should be something along the lines of "Display" and then you should find Backlight somewhere, turn the Backlight to a setting such as 10 seconds, this means it will shut off after 10 seconds of no use. If that does not fix the problem then the lights your Backlight used are most likely dead and you should take it into your service provider such as Sprint, Altel, U.S. Cellular, etc, and have them send it to the manufacturer to get it fixed.
I hope this helps! ~Flascher
Jul 16, 2009 | LG VX8350 Cellular Phone
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Light won't turn off phone flashing
I hope this will help. I had the same problem with the message alert light not turning off. I have phone service through the internet. I would clear messages from my base unit and alert would continue to flash. I went into my internet message center and found a few old messages there. Why they got there is beyond me, but after clearing them my alert light went out and stayed off. I disabled messages to internet inbox and now it flashes only when I get messages to my base unit until I listen or clear them. Easy fix to annoyance I've had for some time.
Nov 19, 2008 | Uniden TRU9480 Cordless Telephone
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
Motorola RAZR V3 - Backlight
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Mar 04, 2008 | Motorola Mobility RAZR V3
Backlight
Unfortunately, the only way to change this is through menu options. Try going into a very well lit room, and then do the following: Menu-->settings-->display settings-->backlight
Nov 17, 2007 | Motorola Mobility V170
LG Shine KE970 Cellular Phone Logo
250 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
