Question about Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers
I CANT FIGURE OUT HOW TO INSTALL SHIFTER CABLE TO XTR ST-M965
I am having problems with the right xtr dual control shifter. Seems to hang up and is more difficult to shift than originally. When upshifting to smaller cog in back with rapidrise DR, I need to double...
Mtn bike shifters get dusty, at the shop when shifter didn't work properly we would wrap the shifter pod in a couple rags and spray WD-40 or Liquid Wrench in there to flush them out, a lot of it, then actuate the shifters and work through the gears, usually takes several times of flushing and working the gears to get them cleaned out. This works particularly well on older bikes that don't "click" when you move the lever. Also make sure you lubricate inside the cable housing and make sure the cables are not crossed in their routing and that there are no kinks or tight turns in the cable routes where the cable could bind up a little.
Jun 03, 2017 | Shimano Xtr Mountain Bike Dual Control...
The shifter moves 9 clicks, but the travel is only enough for 7 sprocket clicks
Shift into the highest gear and then release the shifter cable at the derailleur (it is clamped with an allen [hex] bolt). Pull the cable as tight as you can and re-clamp the cable. You should be all set now. The cable stretches over time and needs to be adjusted.
Dec 13, 2009 | Shimano Xtr Mountain Bike Dual Control...
Dual gate Hurst shifter adjustment
Hello! Here is what I was able to track down:
Hurst Dual Gate Shifter Assembly Parts Breakdown:
Removing & Replacing The Hurst Dual/Gate
1. Disconnect car battery.
2. Remove Knob. Remove four Phillips head screws that hold escutcheon plate down to console.
NOTE: SHORT SCREW IS USED IN REAR RIGHT - HAND HOLE. Remove escutcheon plate and console from floor tunnel.
3. Lift selector indicator lamp housing out of shifter and pull bulb socket out of lamp housing. Disconnect wire connectors from combination Back - up light / Neutral safety switch.
4. Remove two 1/4 - 20 x 1/2 hex-head cap screws that fasten Dual / Gate shifter to rear mounting bracket. Remove 1/4 - 20 x 1/2 hex - head cap screw that holds cable bracket to shifter frame. Remove two #10 - 32 x 3/8 slotted head cap screws that fasten Dual / Gate shifter to front bracket. Free shifter from cable by removing cotter pin and washer.
5. Remove combination Neutral - safety / and Back - up light switch. Install switch on Replacement unit.
6. Install replacement shifter unit in reverse order of removal of original unit.
7. ADJUST CABLE: SEE FIGURE 1 (Below)
Loosen nut that fastens cable pin to transmission control arm. Loosen nut enough to allow pin to slide in the slot in the arm. Turn the arm to NEUTRAL position. Move the stick to NEUTRAL. Tighten the adjusting nut. Test movement of stick and check to be sure that stick positions agree with transmission control operation.
8. SEE FIGURE 2 (Below)
Connect car battery. Apply hand brake. Move stick to NEUTR AL position. Press foot on brake pedal. Start engine. If starter fails to operate, Neutral Safety switch must be adjusted. Adjustment is made with a long-bladed Phillips screwdriver through the "Street" gate. This screw is directly in front of the st ick. Turn the screw about 1/2 turn past the point where starter operates. (STICK MUST REMAIN IN "NEUTRAL" WHILE ADJUSTMENT IS MADE). Starter should operate ONLY when stick is in PARK or NEUTRAL position.
Hope this helps and thanks for using FixYa!
Oct 22, 2009 | Pontiac GTO Cars & Trucks
Wh-m965 race replacement
races cannot be replaced. Keep cones and bearings in good shape and you won't have to worry about it for a long time.
Sep 04, 2009 | Shimano XTR Disc Brake Wheelset
How can i obtain a manual for your microwave model m965 year 1998
you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Feb 23, 2009 | Samsung MW1030WA Microwave Oven
Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers  Logo
315 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
