Question about Troy Garden
DIAGRAM OF PRIMER BULB LINES TO CARBERATOR - Troy Garden
dropndeal
  • 2931 Answers
SOURCE: primer bulb only holds suction, wont move fuel thru line
By "holds suction" this means that you can depress the primer bulb and it remains in the "pressed" position and/or does not reinflate (for lack of a better term)?
You need to determine if a blockage exists in either one of the fuel lines, or with the primer bulb itself.
First, drain your fuel tank. Do this into a clear mason jar or equivalent and inspect your fuel to see if it is full of debris since even very small pieces of grass, dust, dirt, etc... can cause problems. If so, then you need to flush your fuel tank and or lines.
Viewing the backside of the primer bulb, you can see several clear fuel tubing lines that lead from the primer to the carbureator and fuel tank..
Next, carefully remove these using a pair of needle nosed pliers (or by hand is at all possible) being very careful not to crush or tear the tubing.
With the clear tubing removed, if the primer bulb will press in and immediately reinflates back to it's relaxed position, then one or more of your lines are clogged by a small piece of debris. If the primer still does not relax, then it is blocked by a small piece of debris or needs to be replaced (pick one up at Lowes, etc...).
If you determine that your lines may be clogged, then I have had success clearing them with a can of WD-40 by sticking the red nozzle into the clear tubing (attempt to make a seal) and by pressing for a half-second or so. If you get flow, then let it rip for a second, then proceed to rinse your fuel tank again just for good measure (basically until you get nothing but clean gas...no debris).
Put it all back together and let it rip!
Posted on Jul 19, 2009
canbruce75
  • 1776 Answers
SOURCE: Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3200 chainsaw on which I
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Posted on Oct 08, 2009
#1 Taper
  • 1041 Answers
SOURCE: blower/vac fuel lines
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Nov 26, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
When I pump the primer bulb it's not spraying fuel in to the carberator
Fuel lines need replacing or the bulb has a hole or crack in it
Sep 30, 2016 | Garden
How do i route the fuel lines to the carburator ?
Depending on which carb you have it should be the fuel line closest to the bottom on the right side of the carb that goes to the small side of the primer bulb. The long side of the primer bulb will go to the fuel tank as the return line.
Sep 12, 2014 | Poulan Garden
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
I have a craftsman chainsaw 2.2 cubic and there are 3 fuel lines two comming from the primer bulb and one going from carb into the motor or crank. The return is connected to a nipple on the crab and the...
This is a common problem. The fuel lines can become brittle and fracture, or sometimes they swell and will not stay on their connections.
The tube that connects between the carburetor and motor is likely used to pulse the fuel pump that is internal to the carburetor.
The primer pulls the fuel through the carburetor drawing the air out. As the primer is stroked first air than fuel is pumped out of the carburetor. The output of the primer returns to the fuel tank. That fuel line appears to have failed or become disconnected in your craftsman. Either the hose has broken at or near the fuel tank, or has pulled out of the tank. There is a small hole in the tank for many machines. The hole is smaller(providing a seal) than the tube diameter requiring a minor force to squeeze the tube back in place.
Look for the fuel feed tube that also connects from the fuel tank to the carberator. Any loose connections will allow air into the carberator and it will not beable to run.
Important is that the fuel feed tube can not be switched with the return tube from the primer. Connected inside the tank is a fuel filter that protects the carberator from contamination.
Hope this helps?
Jun 28, 2017 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
I have a JD 903 push mower that will only run when i spray starting fluid in carberator. what could be the problem.
Ethanol,dirty filter,or a crack in the fuel line or primer bulb.Clean the fuel system with spay can type of cleaner .Make sure to remove the fuel line,and inspect it for cracks.Make sure to clean or replace the in line filter.Check for more filters in the tank.There is also a screen inside the carb that may be clogged.Also make sure that the primer bulb is in working order.
May 15, 2011 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Homelite blower UT08111 the bubble for the primer will not push
Remove and disassemble carberator clean with gumout solvent (wear safety glasses when spraying) blow out all small holes and passages in carb then reassemble check primer bulb function.
Sep 11, 2009 | Garden
I had to replace the primer bulb and fuel tubing. The primer bulb just disappeared, presumably blew off. I have installed the new bulb and replaced the fuel tubing, but I need to know where the tubes...
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 25, 2009 | Garden
Getting new gas lines in holes in gas tank
I had the same problem. I ended up cutting the fuel line off at a sharp angle. This allowed me to fit enough through to reach with a pair of skinny needle nose pliers. I would also like a diagram of the lines to make sure I hooked them up correctly.
Nov 29, 2008 | Poulan Garden
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
