Question about Standard Horizon Boating
Can i get a battery for a standard hx220s vhf marine radio
Battery model cnb6 425 mah 10 volts
SOURCE: Manual for atlantis radio
http://www.uniden.com/pdf/ATLANTIS%20250om.pdf
Is this it?
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: not receiving information
The same thing happened to me, and I'm just hitting the two-year mark with this thing. I tested it using the aux speaker leads and that still works. So it is only the little front-panel speaker that is broken. And I checked the leads on that little speaker, and they seem fine. So it is the little speaker itself that broke. Easiest repair is to connect the aux leads (red and brown) to another speaker.
Posted on Feb 17, 2010
  • 3 Answers
SOURCE: how to hook up an external speaker to uniden solara dsc vhf
the reddish-orange one and the brown one. The green and yellow ones are for data coming in.
Posted on Feb 18, 2010
  • 64 Answers
SOURCE: IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
Posted on Jun 14, 2010
  • 102366 Answers
SOURCE: need a manual for uniden solara dsc marine vhf
http://www.uniden.com/products/productdetail.cfm?product=SOLARA%20DSC
Posted on Aug 10, 2010
What size supply fuse
I = P/E Current = power/voltage
Therefore 25 watts of power divided by 12 volts if that is the battery voltage, equals about 2 amps. You should try a 3 or 4 amp fuse..
Jul 30, 2014 | Cobra 25-Watt VHF Marine Fix Mount Radio,...
I have a HX460S VHF Marine handheld radio that is not taking a charge. I have purchased two replacement batteries. It works great plugged in. As soon as the AC charger is unplugged the radio dies. Any...
Sounds familiar, but there is a solution here: join yahoo group SPECIFIC to your radio Make/Model, you will receive expert advice and you can download manuals, diagrams and software.
I Know, I am a member of another radio group there.
Cheers,
Peter
Jan 15, 2013 | Standard Horizon Radio Communications
Can this radio communicate with cb channels?
hello unfortunetly not as these radios are resonating on the marine band which is vhf high band cb band is resonating on 27mhz ,marine band 157mhz so will not work .
Apr 02, 2011 | Standard Horizon HX471S (824 Channels)...
The VHF radio receives but will not transmit more than a coulpe hundred feet. I tryed new anntena and coaxe but it didn't help. 12.4 volts going into the radio. Any ideas would be great Thanks Scott
Check the connector on the back of the radio and make sure it is a solder type connector. The connectors that are twisted together never work well. The shield of the coax needs to be soldered to the outside of the connector and the inner portion needs to be soldered to the center.
There also could be a problem with the radio so if that doesn't work I would recommend taking it to a marine electronics dealer for them to test the radio.
May 05, 2010 | Icom IC-M302 VHF Marine Radio
Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Oct 03, 2008 | Raymarine Ray 240 Modular Vhf System
Uniden VHF Hand held Radio HH940
There are several avenues for you. 1. do a serch on ebay for the battery. 2. try your local two-way dealer or 3. go to Unidens web site.
Pat
Aug 16, 2008 | Uniden HH940P Handheld, programmable...
I have a Raymarine VHF marine radio but cannot get channel 37 - why not?
To my knowledge, Ch 37 (M1) is used by the UK Marinas and Yacht Clubs, however, the Raymarine Ray45VHF uses the US VHF Marine Radio Channels allocations/standard where there is no Ch 37 (actually no Chs 29-59).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa
Jun 17, 2008 | Raymarine Ray45VHF (53 Channels) 2-Way...
Any recommendations?
You can find a helpful guide at the following link:
http://www.boatsafe.com/nauticalknowhow/...
Have fun!
Nov 20, 2007 | Icom M302 VHF Radio
Boating Logo
435 people viewed this question
Top Standard Horizon Boating Experts
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
