Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore Canister Vac, Progressive, 25512 255513 model. Brush won't turn. One end of the brush roller, end closest to belt, is off center which is keeping it from turning freely. The end cap is like a square. Other ends turns fine. Do these end caps come off? If so how? Can't get it to budge. This is exactly what is keep brush roller from turning.
  • rlabelle5 Feb 15, 2009
    where can you buy just the replacement squre end caps without buying the entire roller?
    Problem Solver:
  • 12 Answers
Take a flat head screw driver and pry the end cap off. It will come off. You might have some string or hair around it causing it to not turn.
Posted on Jan 31, 2009
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
The brush on the our progressive conister stops and starts. We have replaced the belt cleaned out all areas near the belt and it still starts and stops as if it is skipping of getting stuck on somthing.
Check the brush end bearings for debris build-up and sticking bearings--remove the brush assembly, and pull off the bearing blocks. Clean the pin ends on the brush and the interiors of the bearing blocks with Q-tips, then lightly oil (3-in-one or similar) the bearing blocks and pin ends. Reassemble the brush into the sweeper head without the belt on--check for free turning of the brush. If ok, install the belt, and check for operation. Hope this helps!
Feb 20, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
When i try to use the reset button on my kenmore progressive vacuum, it is having no effect. The agitator brush still will not turn.
Take the time to check to see if the belt that drives the brush is operating correctly. I would also see if the brush itself is frozen up and unable to move. You need to remove the brush in order to change the belt. It would be a good time to clean the brush of all debris and add some WD40 to the plastic tabs at the end of the brush. Add the WD40 and turn the tabs around the brush to make sure the turn freely. Reassemble with a new belt.
If you find this solution to be beneficial, a Thumbs Up rating from you would be appreciated. Paul
Oct 10, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
Belt needs fixed after sucking up a soft rug.
if its a canister model there probably is no belt just suction.open the canister and if it has a bag feel the bag ,if it feels kind of hard then the bag is full.take the tool off the end of the hose and turn it on to see if you have suction if you do then the tool is blocked up.take it to the sink and run some warm water through it and maybe use a little brush to clear out the dirt.full bag will cause your vacuum not to have suction or not as much as it should
Apr 09, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive canister
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552407
Generic problem for all Vacuums
Posted by stupe on Apr 28, 2008
The roller does not turn. The motor still runs alright.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a broken belt or a bad brushroll and either one should be replaced. If the belt is a flat belt, then the belt change is every 4 to 6 months and the extra belt stored in a Ziploc bag in the refrigerator. If it is a geared belt then you would change it every year or so depending on wear and how much it stretched. Also the brushroll should spin freely and check for no thread or hair buildup on the ends and on the brushroll itself.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Mar 24, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
283 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
