Question about Sharp Cartridge Copier Toner/Developer AR-157/168 5012 F152 M155 AR150TD
MY COIPER SHARP AR-M155 DISPLAYS AN ERROR HENCE DO NOT RESOND TO COPY
HELP ME SOLVE THE PROBLEM
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Posted on Jan 06, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 66 Answers
SOURCE: indicating U 2
there will b something else in front of u2 press start to see
Posted on Sep 12, 2009
  • 255 Answers
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Posted on Nov 24, 2009
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
SHARP AR-M155 system error[H4-00]
H4-00,is a fusing troble.maybe the heater lamp is basted, or the thermistor and thermofuse are deffective.or try to cancel by a simulation 14
Jul 05, 2012 | Office Equipment & Supplies
Apr 13, 2011 | Office Equipment & Supplies
HELLO I NEED SHARP USER MANUAL FOR DIGITAL AR-M155 PHOTO,PRINTER,SCANER,AND FAX. PLEASE SEND AS SOON AS POSSIBLE
Here's the manual: http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/AR-M150-M155-_E
Click on the "Download the complete user guide."
Fill out the four question survey or put in the security code to download file.
I tested to confirm that this is the right user manual.
Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Sharp Cartridge Copier Toner/Developer AR-157/168 5012 F152 M155 AR150TD Logo
15 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
