Picotech PT 001 win7 driver - Office Equipment & Supplies
Screen frame broke
Screen frame being the Display Bezel.
http://h10032.www1.hp.com/ctg/Manual/c01573159.pdf
With the laptop closed, the top cover is the Display Enclosure.
Is it broken also?
http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/Detail
Can you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.
The HP part number, for the Display Bezel of the HP G70 series, is;
HP 488386-001
The HP part number for the Display Enclosure is;
HP 488379-001
Base Enclosure;
With built-in modem, Digital Media slot, AND -> with HDMI port,
HP 489114-001,
http://www.impactcomputers.com/489114-001.html
Base Enclosure:
WITH built-in modem, Digital Media slot, and NO -> HDMI port,
HP 501252-001,
http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8
Hinge Kit; (2 each Hinges),
HP 488384-001,
http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001
You have more damage than just the Display Bezel, I feel.
Access what damage you have, and I'll step by step guide you in replacing.
Just post back in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | HP G70-250us Notebook
Motherboard jumpers diagram
http://h18000.www1.hp.com/products/quickspecs/11709_div/11709_div.html
Tells me everything I didn't want to know, lol!
Basic motherboard specs, but no motherboard manufacturer info.
Hmmm,..............
OK,
1) http://www.ebay.com/itm/COMPAQ-HP-D220-MOTHERBOARD-Spares-335186-001-M101-/370624992122?pt=LH_DefaultDomain_0&hash=item564af8937a
2) http://www.ebay.com/itm/HP-SPS-BD-SYS-D220-335186-001-Motherboard-Socket-478-/330531140050?pt=Motherboards&hash=item4cf530f1d2
3) http://www.ebay.com/itm/HP-Compaq-Evo-D220-CMT-Socket-478-Motherboard-335186-001-P4-2-4GHz-CPU-I-O-/380529715263?pt=Motherboards&hash=item589956a83f
Put your mouse in the middle of the photo/s.
Mouse around. (Ha)
Tell me where the jumper/s are.
By the CMOS battery? If so I think you can see where the jumper cap/s sit.
Post back in a Comment.
Regards,
joecoolvette
Dec 16, 2012 | HP D220MT PC Desktop
My firmware Siemens Gigaget SE 261 ADSL doesn't work with Win7 .How I can solve this problem
Everything I see says this modem is too old to have updated drivers to work with Windows 7. I would contact your ISP and see what they would say to use. Sorry! I see nothing wrong with the device except Windows not liking it.
Jun 19, 2011 | Siemens (120-5830-001) Modem
I need driver for win7 32 bit. Compaq Presario V3828AU Notebook PC. the driver not include in hp website.
Run "Windows Update" -- HP puts many of its drivers onto that Microsoft web-site, instead of putting the driver onto any HP site.
Feb 10, 2011 | Compaq Presario notebook PC 30000 Series...
I need a new install disk or download to get my 2wire modem to connect to windows 7 . my old insatll disk dates to 2002 and will not work on my new computer
Did this system come from the vendor with Win7 installed? If not, then you may need Win7 drivers... good luck with that...
If the interface is an "add-on/in" then... you may need Win7 "drivers"... good luck with that...
If all else fails... try calling your ISP... seriously...
Jan 02, 2010 | 2wire (1000-400108-001) Router
I'm need tech support..........
1. You should be able to connect the midi up to the digi 001, if not get an 002, 003. The 001 is so outdated and will not support newer pro-tools software especially plug-ins.I know I had the 001. Now with the 003 rack(love it).and PT 7.4. Research how to plug a midi device into PT.
2.Would google EMU XL compatability.
3.refer to 2.
4. No just memory(RAM)
5.cool...yes why couldn't you?
6.You should be able to come out of the digi, then to a power amp, then the BAs
Aug 20, 2009 | Boston Acoustics (BA7800) Computer...
Emission problems
Lambda sensor on exhaust is most commonly at fault - seems to get the worst conditions to run in.
Try this link to test -
http://www.picotech.com/auto/lambda_sensor.html
Jun 08, 2008 | Cfm 42 Kitchen Hood
321 people viewed this question
k24674
