Question about Coby kyros Tablets & eReaders
My coby kyros mid7048 tablet's camera is not working. it gives me an error saying: "unfortunately, camera has stopped." how can i fix this?
I was able to use it for one week and them suddenly it stopped working. it goes to the camera interface but shows an error when i try to snap a picture
  • 6 Answers
SOURCE: can i download kindle to
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
Posted on Jun 09, 2011
dj_relly999
  • 4070 Answers
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
Posted on Oct 31, 2010
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
SOURCE: How to clear internet history on coby kyros
Go to your url box and click the bookmark button, choose history, press the menu button above your tablet, the one beside the home button. A clear history option will pop out, press it and your whole history will be erased. Hope this helps. :)
Posted on Jun 26, 2011
SOURCE: my coby kyros internet tablet wont turn on
i cannot turn on my coby kyros internet tablet after charging and there are no answers or problem tips in user manual
Posted on Jul 11, 2011
Why is that when I try to downlad anything it says I need a sd card and I have an sd card inserted
do you browse in order to direct the download to your sd card, it might be that it is not found automatically
May 28, 2015 | Coby Kyros MID7048 7" 4 GB Tablet - Wi-Fi...
UNFORTUNATELY I WAS **** ENOUGH TO PURCHASE A COBY KYROS. LESS THAN A YEAR AGO AND NOW ALL THE SUDDEN IT WON'T TURN ON IT WON'T LIGHT UP IT WON'T DO ANYTHING. IS THERE AN EXPLA
check the on off switch and the battery, if its something other than this it will have to go to a repair center . which more than likely will cost as much as a new tablet.
Oct 02, 2014 | Coby Electronics Corporation Coby Kyros...
Coby mid7048 won't boot past Android screen and won't turn off
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
Dec 08, 2013 | Coby Kyros MID7048 7" 4 GB Slate Tablet -...
Words on my coby kyros model MID7048 tablet are backwards. How do I fix this?
If the tablet displays text backwards as if seeing it thru a mirror. This is an indication that there is a physical problem with the device and should be returned to where purchased if you are still in warranty for repair or replacement.
Feb 23, 2013 | Tablets & eReaders
Unlock coby mid7048
  1. Turn off the unit completely.
  2. Press and hold the volume down (-) button.
  3. While holding down the volume down (-) button, press the power button to turn on the unit. Once you see Coby logo on the screen, you can release the power button, but you still need to keep holding the volume down (-) button until you see Android robot logo on the screen.
  4. The "Android system recovery" menu will appear on the screen. The volume up (+) button is used to scroll up in the menu list, while the volume down (-) button is used to scroll down. The power button is used to select and/or enter an option.
Jan 03, 2013 | Coby Kyros Tablet
Will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Mar 31, 2012 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
167 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
