Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Weird sounds coming through speakers
I can listen to the stereo fine as long as I don't start my car but if I start it a weird sound comes through the speakers and gets louder as RPM builds. Is there a way to get rid of this or is the amp screwed? I just replaced the battery and the alternator. And was told that it could be a bad ground but I have reran the ground and shortened it and its still making the sound. Thanx
  • 48 Answers
The problem is not likely the amp. The length of the ground to the amp is not as critical as a good solid connection. Clean any paint and dirt from around the ground connection. It should be clean and shiny metal. Anyway as a test disconnect the RCA's from the amp while the amp is on and see if the sound goes away. If it does then the problem is not in the amp but either the RCA cables, the RCA grounds in the head unit (radio) or bad routing of the RCA cables. Depending on the how old the car is this noise can be coming from your spark plug wires as well. As a last resort you can try a new set of supressor ignition wires for the car.
Posted on Jul 14, 2007
Subwoofer sound weird I don't know what is the
maybe something in the speaker(s) are broken.
Mar 20, 2013 | Audio Players & Recorders
Hi, I have Commell LV-672 MB and I have weird sound problems, its buzzing and making weird sounds when I dont do anything (listen music or whatnot). same is when I use the mic, that weird sound is like...
Open up your computer the speakers plug/outlet is usually at the back of the computer as is the microphone input
to check the lead attached to the rear of the input plugs make sure the connections are good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 21, 2011 | Intel Computers & Internet
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
I was driving and listening to a cd in my cd player... Suddenly there was a weird noise and now the cd player won't work and the cd wont come out of the player... What do i do?
disconnect the stereo clean it out with can of air or a qutip then hook it up if it dont work i got a stereo for you i accept trades!!
May 17, 2010 | Car Audio & Video
Speakers making weird sound
This is the test tone for the speakers, usually means you have connected the input lead into the diagnostic port. The input leads plug into your computer/ipod/TV etc. there may be 2 of them but you only need one plugged in.
Jun 16, 2009 | Harman Kardon HK695 Computer Speakers
When listening to podcasts the voices sound weird
Try updating the drivers for the soundcard. The pitch change could be a sampling rate error.
Apr 17, 2009 | Audio Players & Recorders
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Haveing problems
Hey, fontes,
Let's try to work on this, okay.
First, listen carefully: where does the weird sound come from exactly? The speakers or near the computer case?
Does it play music? Try some salsa and listen again for any difference.
Describe your computer the best you can: Is it new? What make is it? Did you install the sound card yourself?
Hey, Fontes, if you answer these questions, I will be notified immediately and will try to work with you. Comprende?
Adios.
Feb 02, 2008 | Sabrent 6-Channel 5.1 3D Surround Sound...
Subwoofer heard when only B speakers selected
This is really weird. Normally, the subwoofer must be turned off when you turn on B speakers. But, hold on.. I have recently tried to do the same thing as you do, and the result is the same as yours. The problem is that you have to turn off A speakers completely when you activate Bs. If you have an A/B Speakers switch, first push the A to turn them off, after that press "B" to listen to music downstairs. I hope it works.
Apr 19, 2007 | Denon AVR-1603 Receiver
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
124 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
