Question about Onkyo TX-SR500 Receiver
I HAVE AN ONKYO TX SR500 AV RECEIVER WITH A 5.1 BOSE SURROUND SOUND SYSTEM WITH SONY TV. MOST RECENTLY ONLY ONE OF MY SPEAKERS IS WORKING ON MY SURROUND SOUND. ALL WIRES ARE CONNECTED. I CHECKED ALL SETTINGS THEY APPEAR TO BE OK. I TRIED TO DO THE SPEAKER TEST WITH THE TONES BUT IT DOES NOT WORK. THE RECEIVER IS 5 YEARS OLD.BUT HARDLY USED. Can You help today. Steve
    Problem Solver:
  • 5 Answers
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Posted on May 03, 2009
2 Suggested Answers
  • 1039 Answers
SOURCE: onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Posted on Mar 26, 2010
Onkyo tx-sr500. No output to surround speakers.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Jul 04, 2008 | Onkyo Audio Players & Recorders
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Receiver Logo
507 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
