Question about Canon imageRUNNER 5000 Copier
We have an Ikon Image Runner 2200 here at our church building and the front door keeps popping open, please help if you can, thanks!
  • 318 Answers
The door of the IR is held in possition with a magnet.You can just glue tye magnet back in it's housing and the magnet wiil hold the door inplace.Just remember to use a strong glue.
Posted on Jan 26, 2009
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
My ikon Image Runner 2200 has an error message E000003000
All E000 codes have to do with the fixing unit. It can be reset but if the code comes back it will need to be serviced. It has been known to be caused by electrical noise on the main power supply so a filter might keep it from coming back.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again. You should now be in service mode. Select COPIER and this will give you some options along the top. Select FUNCTION. In the list select CLEAR. From the next list select ERROR and press ok. Then switch off machine and back on at the power socket. If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to mess a lot of things up while in the service mode.
Aug 05, 2010 | Canon Office Equipment & Supplies
Canon Image Class 2200 Error code 0322 Can you help me with this problem It will not print at all
this means that you have problem with fixing assy. Best solution would be to replace fixing unit.
And,... did you consider to buying new one,... try with Canon image runner 3225N. Its a NORMAL copier. :-)
Jul 06, 2010 | Canon imageCLASS 2200 Black and White...
I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
Feb 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Adding toner to canon imagerunner 2200
if you have the toner open the front door take toner out of box turn the blue handle on the right side of the copier down which will move thr hopper. pull out the hopper till it stops . take the bottle and line it up so it snaps in place when it snaps in a little tab should pop put pull the tab till it says stop . This process opens the top of the hopper and bottom of the bottle then using your thumbs push the tabs on the front which closes the bottle back. then give it a little extra push and the boyyle will click off
Nov 12, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Image Runner 2200
Hi Willow. If you purchase a genuine drum fom Canon the instruction are in the box. If you have bought a drum from Katun that may not be the case. My email address is jdh6211@comcast.net. I can help you and its pretty easy with a little guidance from me or some one who does this stuff. Let me know if you have the benefit of the instructions as that would be best for you since it has illustrations which are far more helpful than the written word that I would provide you with. No matter what I will gladly help. ...........Spinal
Jan 08, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 5000 Copier Logo
37 people viewed this question
old marine
old marine
