Question about Christie LX505 OEM Projector Lamp
All the lights flash the fan runs continuously and it has trouble powering up and down
The fan runs continuously, even when the lamp isn't on. There are a bunch of colored lights that are flashing. And we are having trouble with powering the projector on and off
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
NHSA275W
1,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Posted on Jul 21, 2015
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Hi guys i have a Mitsubishi WD-65C9 DLP that gives me nothing but a few seconds of audio before shutting off with a blinking red light. ERROR 61
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 27, 2017 | Mitsubishi WD Televison & Video
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
panel, Lens, DMD chip, color wheel,
competitive price.
any questions, feel free to contact me
have a nice day!
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
I replaced the lamp now the lamp light on the frount of tv flashes yelow and tv does not turn on
The flashing yellow lamp light is indicating that the lamp door cover isn't installed properly or isn't contacting the door switch .
Aug 12, 2011 | Mitsubishi Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Model62825 the status lite keeps flashing and I can hear a cpu type fan running but nothing else can u suggest any trouble shooting I might try?
Ralph, I asked for clarification before, however if you are getting audio, the issue is most likely that your lamp needs to be replaced. This is easy to check. Refer to your manual still have it (Page 100), if not here's the link to it:
http://www.retrevo.com/support/Mitsubishi-WD-62825-TVs-manual/id/276ag907/t/2/
Pull the lamp and you'll be able to tell if it has failed because there will be a bunch of chunks of glass rattling around in it. If it has failed, put it back in the TV and get yourself a new lamp. The problem is that your lamp is rather expensive directly from Mitsubishi (Part# 915P020010) whereas the replacement lamps for the more contemporary models are only $99.00. Yours costs $229.00, but I do not recommend buying after-market no matter how appealing the low price seems. They are NEVER the quality of the OEM part and are often refurbished or generic, not designed for your TV.
This something you don't want to cheap out on because you'll regret it in the long run. Also, after-market lamps don't come with the cartridge normally (and when they do, they are almost as expensive as the OEM), meaning that you''ll have to purchase the cartridge separately and actually install the lamp into the cartridge and you don to want to be handling a DLP lamp. It could be disastrous to the lamp and its function.
If it's not the lamp, refer to page 101 of the manual to find out specifically what your particular flashing light indicates.
May 07, 2011 | Mitsubishi Televison & Video
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Christie LX505 OEM Projector Lamp Logo
104 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
