Kenmore mod. 110.27062600, how to remove inner tub from washer.
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Posted on Sep 06, 2007
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washer mod.#110-27062602
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and teardown procedures.
May 08, 2010 | Kenmore 22422 Top Load Washer
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Noise while spinning. Probably a missing coin and part of an ink pen that are missing but not in the tub.
there is an inner and outer tub it may be trapped in between the two. can usually pull aggitator and remove inner tub to check
Aug 01, 2009 | Kenmore 44102 Front Load Washer
Trying to remove inner tub of a Kenmore 60 series washer.
my friend had same problem with his machine. instead he filled it with boiling water and dumped a bottle of no name brand liquid plumber in and let it run through. the smell was fierce but it cleaned it out. this is probably not the smartest or safest way but it is easy. oh one more word VENTILATION!
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
I am trying to clean out all the gunk that has built up between the inner and outer tub on my trusty Kenmore 60 series washer. I have removed the agitator and tried to life the inner tub out to no avail. ...
there is a special nut called a spanner nut. it is about 1 1/2 inches and needs special tool to remove it to get the inner tub out of the unit. you might be able to remove it with a pipe wrench and then you can get access to the outer tub.
i would recommend just using a washer cleaner and trying that first.
these chemical cleaners are designed to remove residues and are much easier then taking the unit apart.
Feb 23, 2009 | Whirlpool LSQ8000 Top Load Washer
Kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Nov 19, 2008 | Kenmore 22642 Top Load Washer
How to Remove the bearing outer race from the shell of the washing machine tub
bearing on most can not be removed there molded in the outer tub comes with the rear half of the tub already installed
Feb 26, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
