Question about GoPro HD Helmet HERO HighDefinition Waterproof Digital Camera Will Fit O
Macbook air won't recognize gopro
Plug my go pro into the computer via usb cable but the computer will not recognise the device
Seagate drive beeping
Wait for it to be recognised and copy off your data before it crashes totally.
Jan 30, 2018 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Help! How do I get the pictures from my Canon Rebel T3 onto my macbook air?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 19, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
What program can I use to upload from my gopro to my computer that is easy to use. It has to be from card. Thank you.
You don't need a program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any phtoto cataloging program, such as Picasa.
Apr 08, 2012 | GoPro Digital Hero 3 Digital Camera
Macbook pro doesnt recognize the panosonic pv-gs9 when connected with firewire
I take it that your macbook pro has imovie on it. If you open up imovie and plug in your camcorder it should recognise the camcorder and give you access to putting the movie onto your mac. Have a look at http://www.apple.com/support/imovie/ it should help.
Mar 03, 2012 | Panasonic Palmcorder PV-GS9 Mini DV...
Computer won't recognize my vivitar vivicam 25
First install u r digital hd video camera driver and then camera software then your pc will recognise your camera and connect with cable usb.
Feb 06, 2012 | Vivitar ViviCam 25 Digital Camera
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
GoPro HD Helmet HERO HighDefinition Waterproof Digital Camera  Will Fit O Logo
552 people viewed this question
Top GoPro Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a GoPro Rock and Ice Climbing Expert? Answer questions, earn points and help others
