Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
The pods won't pierce, they just drop down Nespresso EN90
3 Suggested Answers
  • 23 Answers
SOURCE: nespresso essenza en90,o
I opened up my krups nespresso xn 2105 essenza C100N machine today. It was not starting up quick enough, so silly me decided to dunk it in hot water. My nespresso is an automatic, it has the on/off switch down in the back. My guess is the water that went in there is what is killing the house fuse now. So I really needed to open it up. Not knowing how to proceed, I looked at fixya first, No details yet. So here is what I did.
I looked at the screws, (post on fixya suggested they are screws) at the bottom. There is 6 of them. They look like rivets as if they have been made into round blobs after putting them in. So I took a dremel-like small grinder (a really small drill would do better) and made two small notches on the side of each one. Be careful not to chip away too much plastic of the machine ;) Then I used very small and long pliers to get them turning. That is actually easy, they are lightly set in plastic. Hard part is to keep the pliers from sliding off. Actually once loose the most of the turning I did using a narrow rubber tube, I guess you could use the rubber on the back of a pencil as well. So, remove 6 bottom screws, actually you can remove the sides now. This gives you access to the area where you can see all the wiring and many of the parts. For me I needed access at the bottom, so I removed two more screws near the bottom, and removed the bottom plate. The on/off switch for the automatic sits down the back of the machine, there is one additional screw (six pointed star shape) in the internals for this. I did pull off the switchy bit of the switch - do not do this as springs andcontacts fall out... Mine also still has water in there so I guess I found my problem.
Well, thet is how to dissassemble. I will have to find out how to reassemble tonight, to be able to get my wife het coffee in the morning ;)
Posted on Oct 17, 2009
  • 1833 Answers
SOURCE: Nespresso C190 is not piercing the top of the
According to your problem first open the coffee container and clean it properly. After cleaning fill the container with proper quantity of coffee beans. May be the spout holes are blocked. So clean the spout by pin. Also make clean the infuser by open the front cover of the infuser. The ground coffee may be blocked in the funnel. Remove the ground coffee inside the funnel using a knife. Then clean the infuser and the inside of the appliance. Descale the machine. It will help you.
Posted on Jun 13, 2011
The lever to puncture the Nespresso pods will not fully latch when pulled down. The only way to have the Nespresso machine brew a cup is to hold down the lever until it is completed.
do not fors it you may have problems wi the piston try runing some worm water with out any capsule until it is flowing properly you may have some blocking in th esystem
Aug 15, 2017 | Nespresso Coffee Makers & Espresso...
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
My Nespresso U is sending the coffee out where the pod drops down not through the spout
YOU MUST CLEAN THE SPOUT TO MAKE WAY FOR THE WATER FLOWN PROPERLY TRY RUINING SOME WORM WATER FERST TO CLEAN UP AND MELT THE STUCK COFFEE
Oct 30, 2015 | Nespresso U C50 Espresso Machine...
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
Why my nespresso c110 cofee machine will not pierce the top of the pod and thereFore no coffee.
Are you using genuine Nespresso capsules? Any other kind will cause the machine to malfunction.
Feb 13, 2015 | Nespresso Coffee Makers & Espresso...
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
The pods are not being pierced and the coffee is coming out too weak. Help!
The capsules are not pierced when they are inserted. They are pierced on the back but not in the foil. The foil is pierced when the hot water is injected through the posterior holes and the pressure causes the foil to bulge, thus getting pierced by the grid in the front of the machine. If the capsules are not getting pierced it means that the water is not being injected with enough pressure. This could be due to hard water deposits. Try first to pump the machine by turning it on and then lifting the lever and keeping it raised for a few seconds. If that doesn't work, de-scaling the machine should correct the problem.
Aug 10, 2011 | Nespresso Essenza D100 Espresso Machine
Recently the machine started dispensing VERY weak (mostly water with a very light brown see through color) coffee. It does not happen every time although all coffee seems weak. It looks like the pods...
Hi imhofag,
The first thing to do is clean the projections on the piercers. Gunk will build up on them and they need to be cleaned periodically.
I would need your model number in order to help you take it apart.
Please reply if cleaning the projections doesn't help.
Thanks,
Handie Andie
Jun 11, 2011 | Nespresso Coffee Makers & Espresso...
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
57 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
