Question about GE Heating & Cooling
Control panel for GE air conditioner price lists
Need price of control panel for ge ac
SOURCE: I have a 51GR Carrier window air conditioner and the
TRY:
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
Posted on Jun 27, 2009
daddyo742001
  • 70 Answers
SOURCE: I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Posted on Jun 28, 2009
SOURCE: the compressor on my GE ASH10ABS1 window air condi...
when attempt to I power up my GE window unit, a message
' E1' shows, and the unit does not start. what is it telling me ??
Posted on Jun 12, 2010
dvs_redstorm
  • 81 Answers
SOURCE: I need to replace the
you can get a universal tv remote that also does air conditioners or a remote that does all air cons but there costly.
Posted on Nov 09, 2010
  • 9 Answers
SOURCE: I need a GE Air
Try: Replacement Remotes.com
I have done business with them myself and they have always been very helpful. They offer reasonable prices and speedy service.
I hope they can help you. GOOD LUCK.
Posted on Jan 28, 2011
I need a wiring diagram for a ge window air conditioner
Need model number to try and find you one. Older ge air conditioners had the diagram glued to the inside of the outer case. Newer ones had a sheet of paper folded up and stuck near the control panel sometimes in a plastic envelope.
Jun 09, 2015 | GE Refrigerators
Where do the black and white wires with the connector slides go in the electronic control box? AC unit AGH08AJG1
There probably are matching connectors in the control box identified for AC + (black) and AC - (white).
Jul 01, 2014 | GE Heating & Cooling
Ge zoneline not blowing hot air at all
step one check fuse located in control panel . next step the control pc board inside the unit should be a paper schmatic with control board part number. enter part number on ebay . most of the time the control board goes bad its usually about 150.00
Jan 08, 2014 | GE Zoneline AZ55H07D Air Conditioner
GE APE07AHM1 Won't Run
This unit has a famous problem with the control panel. Try to use the remote to turn it on, instead of the panel. I had the same problem.
Jul 18, 2013 | GE APH10AA Air Conditioner
I need a GE Air conditioner Remote control #6711AR2853L
Jan 27, 2011 | GE AJCQ08ACB Air Conditioner
I have a GE APH10AAG1 portable ac that has no control panel function. It does turn on and blow cold when pluged in. It does have some LED's that light up (dry, low fan and the display). But none of the...
I have the same problem, Just use it with its remote control. if you dont have it you can order it through sears parts : part# DG11A2-04 (GE) or 81401789
Sep 23, 2010 | GE APH10AA Air Conditioner
Recharge freon ge heat & ac unit
Jump out the control, make the machine run constantly and recharge it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 21, 2009 | GE Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
