Question about Ricoh Caplio R2 Digital Camera
Camera turns itself off
My Caplio R2 has developed a problem. When sliding open the shutter to turn it on, it almost always automatically turns itself back off again- like the switch attached to the slider is faulty (or has become detached from the camera innards). Tapping the camera (or slider) sometimes tempoarirly reactivates the camera but the slider is very finiky- slightly touching it will deactivate/ activate the camera. How do you open this camera to examine the switch. It is a MAJOR problem. The camera is out of warranty. I am good wth repairing micro electronics. Is there any info out there (eg- a manual) which explains how to disasseble this camera.
  • 1 more comment
  • fromholland Feb 05, 2008
    Finally someone with the same problem! When i open the sutter of my Ricoh R2 to start up the camera it shuts down immediatly very often. somethimes after several times it start working proparly again. I have not fond a solution yet. IM from Holland
  • Anonymous Feb 12, 2008
    Yes, we have the same problem. It gets frustrating and just wipes out the original point and shoot feature. The camera had been flawless.
  • RMSconsult Feb 18, 2008
    Hi Newton63,
    We have the same problem.
    Do you have any tips on opening this up, and a source for the part?
    Thanks.
I have the same issue, I've pulled my camera apart, it's a faulty contact in the slider on/off switch assembly. I'm planning to remove the slider ass'y and check the contacts. Ricoh state it's a common problem, new switch ass'y is about $40 AU
Posted on Feb 06, 2008
SOURCE:
Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
Oct 30, 2012 | Office Equipment & Supplies
Blurred image after switching on camera (takes blurred pictures ). Only cure is to slide the sound/film/camera button up and down until I see a clear image in the viewfinder screen. Often unsuccessful...
The four main causes of blurry photos are:
  1. Out Of Focus
  2. The subject moves while the shutter is open
  3. The camera moves while the shutter is open
  4. Depth Of Field is too shallow
About the battery catch, visit some technicia shop to solve it.
Oct 05, 2011 | Ricoh Caplio R4 Digital Camera
Tried to format new memory card for Ricoh Caplio R2. Camera just shuts down, no error messages etc. Card is an SD HC high speed 8 GB one.
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Jan 27, 2011 | Ricoh Caplio R2 Digital Camera
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Download to vista
you can download it from below given site:
www.ricoh.com/r_dc/download/
rate my solution
Sep 05, 2008 | Ricoh Caplio R2 Digital Camera
Ricoh camera malfunction
The problem eventually fixed itself somehow.
Mar 17, 2008 | Ricoh Cameras
Shutter door does not open automatically
Hello, just recently ran into the same problem. What is the best way to get spring out of there. Slight manual pressure isn't working.
May 06, 2007 | Canon PowerShot A520 Digital Camera
Ricoh Caplio R2 Digital Camera Logo
161 people viewed this question
Top Ricoh Cameras Experts
Bill DeLisi
Bill DeLisi
mbutkus
Level 1 Expert
Ekse
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
