Question about Acer Aspire™ T180 PC Desktop
Adding memory resulted in system failing to boot
I have an Acer Aspire T180 which came with two half gigabite memory modules and two spare slots.
I added a matched pair of 1gb modules to the two spare slots and got a 'blue screen'. I then replaced the supplied modules with the new ones and everything worked. I then added the 'old' modules to the spare slots and got another blue screen.
Any ideas?
  • 6 more comments
  • reed_blackbi Jan 25, 2009
    No - I added the memory to the spare slots so there were now 4 memory modules and then booted up
    No
    The first two are one colour and the second two are another. As supplied, the memory was in slots 1 and 3
    You are testing the limit of my knowledge but I am assured that they are compatible - and in any case, the machine runs perfectly with either the old or the new memory, but not with both.
    But if you want to add memory how can you avoid it? and the memory installed when it came used one slot of each colour.
  • Anonymous Jan 29, 2009
    have mixed and matched the old 512 mb with new 1gb in both purple and blue slots, upgraded bios (phoenix technologies) and still with all four 1 gb matched speed i still get only 1gb memory showing, using vista 32 bit. spend 30 minutes with bios tech support and apparently this is an issue on the acer aspire T180 ..will try tech support today from crucial "chat" tech to see if they can shed any light on this issue for all of us. ready to pull hard drive, stick in an external shell...buy another brand (like hp) that has tech support.
    gary
  • Azz
    Azz May 11, 2010
    I know this probably sounds obvious, but are you sure the memory modules are compatible with the motherboard? DIMMs are backwards compatible but not the other way round eg. Higher performance DDR2 DIMMs are compatible with lower performance DDR2 DIMMs; however, the higher performance module runs at the lower module's frequency. Same goes for DDR DIMMs.
  • Roberta Smith
    Roberta Smith May 11, 2010
    are all the slots the same colour ?
  • Roberta Smith
    when you added the memory to the spare slots... did you remove the other memory before you booted up ?
    Robert
    Brigadier General:
  • 5,158 Answers
You can use only one set of slots (by colour) not both
Posted on Jan 25, 2009
    President:
  • 948 Answers
Let's get some information about the memory you are using. Get CPU Z and run it with the new memory, then switch back to the old memory and run it again. Write down the results from the memory tab and the SPD tab (all slots being used). You want to make sure that your timings match to give yourself the best chance of success. All of your memory should be DDR2 533 (PC2-4200). SOMETIMES you can use faster memory and it will simply slow down and function. Other times it will not.
  • Dick
    Dick Jan 25, 2009
    "the machine runs perfectly with either the old or the new memory, but not with both."
    Which is exactly why the symptoms point to memory incompatibility. Not due to the memory modules themselves, they don't care. But due to the motherboard. Some bios can force memory timing for a particular slot but I doubt your computer can. Worth checking though, good luck.
I have a acer t180 deck top when i power up i get 1 long beep can u help
Hi.
One long beep on an Acer desktop computer usually means the memory may be loose or faulty. Turn the computer off and remove the side panel to expose the motherboard, In there you will find the memory modules and slots. Unclip the memory and clean the brass contacts and the slots themselves free of any dust, then reseat the memory one at a time turning the computer on to see if you get a post/splash screen, it could just be a case of a build up of dust and there will be nothing wrong when you have cleaned the dust away and reseated the memory.
Regards.
Feb 04, 2013 | Acer Aspire™ T180 PC Desktop
I have a acer aspire t180 gb7z pc and i would like to know what is the maximum ram speed i can upgrade to
You have 4 slots, capable of handling 4GB of memory but CAUTION: most machines come installed with 32 bit Windows OS. To maximize memory you must have 64 bit Windows OS. With 32 bit system, its probable that 1GB will be all your machine will handle.
Oct 18, 2009 | Acer Aspire™ T180 PC Desktop
I purchased two 1GB pc2-4200 memory sticks and my Acerr Aspire T180 wont recognize it. It starts beeping and wont Boot. The reason I bought them was that my computer was running very slow after I re...
Hello there:
first off you will need to ensure that the memory that you have purchased is fully inserted in the slots next ensure that the memory is compatable with the motherboard that you have and your system
go to the manufactures web site of the computer and there will be a technical support option there with phone numbers to help you.
Also you may also want to swap slots with the memory sticks and see if this helps ok so please try these ideas. ok
best regards mike
Jul 31, 2009 | Acer Aspire™ T180 PC Desktop
Want to add more memory to aspire t180 ast 180-ud400b
According to Acer's website, your system uses this memory configuration...
256MB DDR2 533/667/800 SDRAM expandable to 4GB
My suggestion to you is, if you have the original 256 loaded, find a good bargain on DDR2 667, one gb memory modules and REPLACE what is installed, instead of adding to it.
If you add to it, and it is the incorrect speed (that's the 667 number), you may experience some very undesirable results.
good luck
tony
PS. This advice is posted assuming you are aware of the dangers of ESD, and you have some technical experience on the inside of a computer. If this assumption is false, please share this advice with your technician to get the correct memory upgrade.
Jun 17, 2009 | Acer Aspire™ T180 PC Desktop
Acer desktop failing to boot
Some times when computer boot and hang with amber or yellow light it is a memory error not allow computer to post. You can try to check your memory by taking them out and re-seating them in place then trying to boot or trying using the memory in a different memory bank slot. One other thing is to remove the memory computer and remove disconnect the hard drives and CD/DVD-ROM to see if you can get the system to post. Start adding the components back one by one to see if any of them are causing the system to halt.
May 04, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Wont boot with all memory slot filled
What is the make and model of your computer? Have you tried using the modules that you took out and replace with the ones that you know are working incase the modules could be bad?
Apr 08, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 PC Desktop fails to boot
You can use ERD commander to boot the system, backup your files to any other partition except first partition.
I am sure you have software related problem.
May 08, 2008 | Acer Aspire™ T180 PC Desktop
Ram memory conflict
adjust memory timings inbios and check u sitted it correctly.
Apr 04, 2008 | Acer Aspire™ T180 PC Desktop
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
151 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
