Question about Toshiba SD6100 DVD Player
How to reset the default value for the toshiba sd 6100 dvd player
Toshiba sd 6100 dvd player
I used the remote control and perform the setup function->video out->HDMI then change the HDMI resolution to 1080p now nothing dispaly on my TV just blank. How to reset the dvd player to the default value. please help
  • wswwong Jan 25, 2009
    find my own solution, disconnect the HDMI cable and connect TV to DVD player's composite video output the video should display again on the TV then use the remote to reset the default setting
  • 3 Answers
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Posted on Jul 18, 2009
My toshiba flatscreen says retail unlock on it an it wont do nothyn.. how i fix it without original remote
You can reset and eliminate the lock on some televisions without the remote.. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television. Wait several hours before reconnecting the plug and reattaching the battery.
You say you have a Universal remote. If you have not done so yet use the procedures that came with your remote to install it on your Toshiba. After using the install procedures you should at least be able to power on and off the TV.
power the TV on and then do the following:
TOSHIBA specific advertisements or "Retail Lock" at anytime when operating, perform the following procedure:
  1. Using the remote control, press 1, 2, 3, 4 in this order. This will release the "Retail Lock" mode.
  2. Perform a factory reset of the TV
  3. Resetting Factory Defaults:
To reset all settings and channels to their factory default values:
1 Press the MENU button and open the Installation menu.
2 Highlight Reset TV, and then press the ENTER button.
3 Enter your PIN code (If a PIN code has been set).
4 A con?rmation screen appears. Select Yes, and press the ENTER button. The TV will turn off automatically.
Then do the following:
  1. Power on the TV. You will be prompted to perform the first time setup.
  2. Be sure to set the Location option to Home.
  3. Continue with the first time setup.
The "Retail Lock" should be disabled and you can now use all the functions of the TV.
hope that helps
Jan 23, 2015 | RCA Televison & Video
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
I own a Toshiba SD-1200 DVD player but have lost the remote control. Without the remote control it is useless; you cannot play DVDs on it because there's no "Enter" button on the DVD player...
looked around for you couldn't find a new one but i did find one at this link,
http://cgi.ebay.com/Original-TOSHIBA-DVD-Remote-Control-SE-R0030-SD-1200-/400098986865?pt=LH_DefaultDomain_0&hash=item5d27c20b71
Jan 23, 2011 | Toshiba SD-1200 DVD Player
I have a Toshiba SD-590KV2, I hit the Default setting under the Misc setup and the picture flips up like there is no horizontal hold. I disconnected it for a while but same thing happened. How can I fix...
I just did the same thing...
Using your remote press the keys in the following order:
1. Setup
2. Down Arrow
3. Right Arrow
4. Down Arrow
5. Down Arrow
6. OK
7. Up Arrow
8. OK
9. Left Arrow
10. Ok (After this the screen should be legible)
11. Press OK one last time to save the setting before it reverts to the PAL setup and you have to do all of this again.
Good Luck!
Dec 07, 2010 | Toshiba SD-590 DVD Player
Need the code for one for all universal remote to
The code for a URC-3021 to control a Toshiba DVD player is 0503.
To setup your URC-3021 for the DVD player, these are the steps:
1. Turn on your DVD.
2. On the remote control, press DVD once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 25, 2009 | One For All URC-3021 Remote Control
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
Programming for a DVD Player
Menu>Parental, Fav's & Setup>System Setup>Remote>Program Remote. From here, just follow the onscreen insructions. Enjoy!
Sep 15, 2008 | Directv RC23 Remote Control
Region free?Toshiba SD-140E
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)
I found this for other Toshiba SD dvd players, yours was not listed but might be worth a go.
Oct 25, 2007 | Toshiba SD-140E DVD Player
Toshiba SD6100 DVD Player Logo
954 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
