Question about GE DBXR463EBWW Electric Dryer
After starting,it runs for a couple of mins.,then shuts off,
Then the top of the dryer gets so hot you cant touch it,but after ,about 5 mins,it works good
  • 686 Answers
It's over-heating sounds like you have a bad thermal switch
Posted on Feb 18, 2009
Tumble dryer turns off 5 mins after starting
The most likely cause is a clogged venting system or operating thermostat. Also check to see if your dryer is hot to touch after a few minutes of operation,if so remove your vent in the back and try running the dryer without it and see if it makes a difference, good luck
Feb 17, 2018 | Dryers
Why won't my dryer start?
MAY HAVE BLOWN A THERMAL SHUT OFF THERMOSTAT DUE TO OVERHEATING, CHECK UR VENTING ASLO
May 23, 2014 | Kenmore Dryers
My john deere 210 runs for about 40 min just fine then it dies. Then the problems begin and the engine hood is so hot I cant touch it. I can restart it and limp it back to the garage and wait for 20-3
was the piston replaced with the wrong one?locking up in the bore when hot?where the rings wrong as well take it apart and check the clearance before the bore is damaged
Apr 24, 2012 | John Deere Garden
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Dryer shuting off in 5 min top getting very hot
Is the motor getting hot or is the element not shutting off?
If it is the motor then it is going bad...
If it is the element then the thermostat is bad and will just heat till the high limit shuts it down...then replace the thermostat and the high limit now that it has been activated...
here are a couple of tips that may also help you...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | General Electric DBXR463EG Dryer
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
Start/pause button not working, is it the control panel or the control electronics board?
First unplug the Dryer and allow about 5 mins to pass, this will allow the board time to reset, plug Dryer back in, if problem is still present, its possible that the touch pad is defective on the dryer, if other functions work when touched, it is the touch pad, and not the Board
May 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our amana gas dryer. runs for about 20 mins and shuts off. try to resart and there is busing noisefrom the controls on top. if sets for 45mins. it will start again. until it gets hot. and then wont work.
The problem is in the gas valve coils. They sit on the top of the gas valves. When these coils are energized open the gas valves and allowing the gas to burn. If one or more coil malfunctions, the dryer shuts off. It is usually difficult to properly test the coils and replacement is the best solution.
Sep 25, 2009 | Amana Dryers
Dryer running super hot
you could buy a dryer snake, there could be a build up in the hose
Sep 06, 2009 | Kenmore 73952 Gas Dryer
GE DBXR463EBWW Electric Dryer Logo
112 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
