Question about Microsoft Xbox 360 Console
Picture freezes error e79 comes on screen one red light flashes machine just out of 12 mth warranty
  • lionel_smith Jan 26, 2009
    thanks 4 trying tried another harddrive still the same i guess its microsoft 1 me nil perhaps ill buy a sony
    Novelist:
  • 174 Answers
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. If it works with the hard drive removed then you may have a faulty hard drive m8. To test your machine before you buy another one, borrow a mates hard drive and test it in your machine, if you get the error code again then something in your machine is faulty. If it loads ok with a different hard drive then yours is definately the problem. www.fixmyconsole.co.uk
Posted on Jan 26, 2009
    Scholar:
  • 35 Answers
You might check out the Informative article at Ezinearticles.com to fixthe freezing problem as the article gives the information about a DIYguide, (though i don't remember the name of the site) but you can checkthe article from http://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369
Posted on Mar 07, 2009
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Got a green light in the centre and bottom rt is red,can`t do a thing with it,any ideas?
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove
Sep 16, 2010 | Microsoft Xbox 360 Console
My 360 will play movies all day long, but when I put a game in it plays for approximately 3 minutes and shuts off. The lights on the left side of the power button flash red. What is the deal?
Sep 15, 2010 | Microsoft Xbox 360 Console
One flashing red light on player 3 and 4 alternate flashing E79
E79 is a hard drive problem. It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Dec 27, 2008 | Microsoft Xbox 360 Console
Bought a new hard drive for the xbox 360 ,and after running the upgrade all I get when I turn it on is a system error and a red light flashing on the console
Take a look at the screen you should find a number for the error code there like E80 or E79.
If it is E80 this means that the update went wrong and that the consoles kernel wasnt flashed completely.
This can often be fixed with an NXE update recovery disc, search for it on Google, you can download it from Xbox.com.
If you are getting an error like E67, E68 ,E69, E79 or something similar it will be harddrive related very likely, disconnect the harddrive and try to power the console if the problem is gone get a harddrive replacement, call Xbox Support they will take care of that...
If you should be getting a different error code take a look at this error code list this will tell you whats causing this certain error and how it can be fixed: http://xbox-experts.com/e/errorcodes.php
I hope this helps.
Kind Regards,
Wilhelm@Xboxexperts.com
Dec 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 freezes up
it might be the ring of death i am not sure sorry
Aug 25, 2008 | Microsoft Xbox 360 Console
Xbox 360. got an error message E79 and 4 red lights. Now it freezes up at reume game. What do I do.
All four lights means there is a problem with the av cables, check to make sure they are in all the way, but that is inconsistent with the E79 error, which is a hard drive error. Check the cables, then try running your machine without the hard drive. If all else fails, or if the hard drive is bad and under warranty, call 18004myxbox and get it fixed. If you need to send it out and will cost $ ask to speak to a supervisor, and they can usually get the cost down a bit. Good luck.
May 06, 2008 | Video Game Consoles & Games
Nooooo
Here is what I found for error code e79:
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
You might want to get in touch with microsoft and see what they suggest to fix this problem.Here is a link to their support site:
http://www.xbox.com/en-US/support/?WT.svl=nav
Apr 08, 2008 | Microsoft Xbox 360 Console
Bottom right ring light flashing red and E 74 appears on the screen.
There are a ton of errors that can occur what error did you get E45-E79 there are about 15 total errors for the bottom right light flashing but generally it is Hardware failure. Could be DVD drive Hard drive. Would help more if you havd some numbers or something.
Oct 28, 2007 | Microsoft Xbox 360 Console
E79
hello Mostafa the E79 means : Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption. I whish this solution will solve your problem. MOHAMED AMINE
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
132 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
