Question about Kenmore 9387x Top Load Stacked Washer / Dryer
Why does my dryer belt squeal for a FEX831CS Top Load Stacked Washer / Dryer
SOURCE: Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Posted on Jul 20, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
j_alcaidinho
  • 107 Answers
SOURCE: My Kenmore 417.94812301 stacked washer/dryer makes
What you need to due is take front off dryer and either you're blower is making the noise, or the idler pulley and even the support wheels could be as well
Posted on Feb 26, 2010
My washer makes a loud squealing noise when it spins, what is wrong
Hello Kathy McAlister - Typically, when the washer is making or produces a squealing sound is due to an overloaded load. I recommend running a cycle with less clothing. If issue continues, then consult with a professional to accurately pinpoint any potentially more serious issue like a faulty belt or a bearing/pulley suspension problem. The washer could possibly have broken something off in between the tub and outer portion of the unit.
Feb 23, 2013 | Frigidaire FEX831CS Top Load Stacked...
How to replace v belt
Are you looking to replace the belt in the dryer portion of the stacked/combo unit?
Sep 23, 2012 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire combo unit the dryer is squealing?
the felt that rounds the drum that touches the front panel could also be worn and you can have a situation where metal is rubbing
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dryer heats up but does not rotate - only squeals
Check to see if the dryer drum will turn by hand. If not, look for a sock or other small garment that may be wedged between the drum and the dryer. It's remotely possible that the bearing has seized.
If the drum turns fairly easily by hand, the belt is probably loose (worn and stretched) and needs replacement. Check repairclinic.com for the part and a how-to video, if you want to try to repair it yourself.
Apr 29, 2011 | Frigidaire FEX831CS Top Load Stacked...
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 9387x Top Load Stacked Washer / Dryer Logo
15 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
