Question about Telex Airman ANR 850 Headset
My telex Airman 850 no longer "noise cancels". What's the problem?
How can I wire a Road King 5-wire to a 4-pin Galaxy Saturn?
Search for CB TRICKS on the internet. All the information you could ever need for this type of information is at that website.
Mar 26, 2016 | Telex / RoadKing RK564P Road king 4-pin...
How can I connect a Road King 5-wire to Galaxy Saturn 4 pin?
attach the wires according to the schematic you got with the radio telling you what wires do what. Those wire go on pins 1 - 4 The yellow wire is not connected.
Mar 26, 2016 | Telex Road King RK56 4 Pin Noise Canceling...
Wire 5 wire with 4 wire plug
You need a wiring diagram for the radio and mic. or take it to a CB shop.
Oct 10, 2014 | Telex Road King RK56 4 Pin Noise Canceling...
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
Telex ZING ringing noise
go away
i dont want an assistance plan.
Sep 16, 2008 | Telex ZING A/D Conversion Card (300801000)
Telex Airman ANR 850 Headset Logo
29 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
