Question about ASUS P5RD1-VM Motherboard
Cmos battery is dead
I have an emachine notebook model number w4630 and the cmos is bad. want to replace it but can't find it. any suggestions?
  • maxgal Jan 25, 2009
    Do I have to take apart the whole computer?
  • 98 Answers
You will need to open the laptop from the bottom the battery is on the boare very simple to replace it could be one of two batterys cmos battery is dead - ffc4efc.jpg the second battery is incased in yellow or blue plastic with to wires helping it to sit in the conputer better
Posted on Jan 25, 2009
    Brigadier General:
  • 5,158 Answers
Round metal watch style battery on the motherboard about the size of a quarter... walmart would probably have them in the watch dept.
careful removing the battery so you don't break the clip that holds it in.
Robert
Please take a moment to rate this solution.. thanks
Cmos battery number
It is probably best to remove the battery and look at it for the number.
Jan 15, 2014 | eMachines ET1161-05 PC Desktop
My question was the battery for the desktop and where is it in the tower?
These might not be your specific computer but it might give some insight onto the location of cmos battery and what to look for.
How to Replace the BIOS Battery http://www.youtube.com/watch?v=tkBWZOtp2is How to replace dead CMOS battery and configure BIOS settings http://www.youtube.com/watch?v=0q2RIaCICKU
Feb 22, 2013 | E-Machines eMachines Desktop PC
CMOS checksum bad Press f1 to run setup Press f2 to load default values and settinss Keeps comming up on star up
Your CMOS battery may be dead. That is the watch style battery on your motherboard. Choose f2. If the problem persists, change the battery
Feb 28, 2011 | E-Machines eMachines Desktop PC
Low battery warning message on boot up
I'll give you the info for the cmos battery but afterwards observe any other issues with your notebook. Your notebook is not new anymore and may need other servicing besides a new cmos battery.
It should be housed driectly undeneath you notebook on a panel you can remove that houses the ram.
If you still cant find it, you may have to physicaly take apart the unit. I would search under the keyboard and all four corners of the motherboard and center. Just in case.
Let me know how it goes.
P.s: Be very careful If you are not use to opening up notebooks then I suggest taking unit to a professional for them to replace the cmos battery.
Mar 07, 2010 | Acer TravelMate 244LC Notebook
Emachine M622-UK8X won't power up. When plugged in all the panel lights come on, but stay on. power button has no effect. cmos battery good. Does not smell burnt. Any suggestions?
you might try removing the battery pack. and power up the laptop using only the wall connector that came with it. sometimes a bad battery pack is the cause of power up problems.
Dec 25, 2009 | E-Machines M2105 Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
Why won't new PNY DDR memory work in eMachines W4630?
Read your manual, as there website does not offer it just driver downloads.
Also, just because it is the same kind does not mean it will work.
That is why most MFG of motherboards have a quality vendor list
for memory. There are thousands of people who can't get some mfg's memory to work with there systems when the specs are the same.
But I would go with what Ultim said and there might be a slot limit.
Mar 20, 2009 | Computers & Internet
I have an emachine w4630 notebook. i can't find the cmos battery which needs changed. do i have to to take the back off my computer?
I do believe you may have to partially disassemble to get at battery. I have found the manual on line that you can download at the below address:
http://www.manualnguide.com/dl/9176/
the manual shows you where battery is located and how to change it.
took a bit to find, please be so kind as to take the time to rate this answer. good luck and thanks
Jan 25, 2009 | ASUS P5RD1-VM Motherboard
Acer 3001 Wlmi CMOS Dead
The best place to search the manual from this site link
http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/3b1edf692d19ce1e48256fd600068b2e?OpenDocument
the manual is here,it covers specs etc....
Have you tried ac power pack without battery attached?
if it is a cmos fault then battery will be on motherboard
battery number should be on battery
Jul 09, 2008 | Acer Aspire 3000 Notebook
Emachin
Sometimes this problem happens when your CMOS battery already dead. Replace the CMOS battery and run F4 to setup the date and time. Save it and you back to business.
Mar 27, 2008 | Dell (E210882) Motherboard
ASUS P5RD1-VM Motherboard Logo
111 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
